    29 Posts 5 Posters 18.3k Views 3 Watching
      Martin Kudláček
      this really seems to be an issue on our part, probably related to the firmware of the extensions. You are not the only one having the exactly same problem (see https://forum.unipi.technology/topic/652/how-to-add-xs40-to-neuron-l203-using-custom-software/42). We will investigate it a bit more and let you know as soon as possible.
      Thank you for your patience,
        salorob
        Ah.. okay. Well, at least I'm not crazy.
        Please let me know, I need to get this setup running asap.
          Martin Kudláček
          ok, to get your setup running ASAP - would it be possible to use Teamviewer or direct SSH to the controller so we can check what's happening? We will check the extension's firmware version and do the FW update if neccessary.
          The best time would be between 12:00 and 20:00 CEST.
          B 1 Reply Last reply
            salorob
              Martin Kudláček @salorob
                bsc101 @Martin Kudláček
                Boris
                  Martin Kudláček @bsc101
                      1. SSH into your controller, the user "pi", the password (if not changed) is "raspberry". If your image is Raspbian, you need to install additional packages:
                      pi@raspberrypi:~ $ sudo bash
                      root@raspberrypi:/home/pi# echo "deb https://files.unipi.technology/debian stretch main" > /etc/apt/sources.list.d/unipi.list
                      root@raspberrypi:/home/pi# wget -O - https://files.unipi.technology/debian/unipi_pub.gpg | apt-key add
                      root@raspberrypi:/home/pi# apt update
                      root@raspberrypi:/home/pi# apt install -y neuron-firmware neuron-modbus-tools
                      1. Connect the extension to the controller over RS485. If you have multiple extensions, connect only one at a time. Right now, all of them thinks they have address 15, so you need to avoid collisions.
                      2. Confirm, you have a connection to extension
                      root@L503-sn101:/home/pi# /opt/neuron-bin/fwserial -p /dev/extcomm/0/0
                      Boardset:     5 E-14Ro_P-11DiR485              (v1.0)
                      Baseboard:    2 E-14Ro                         (v1.0)
                      Firmware: v5.6
                      Modbus timeout set
                      1. Flash the firmware
                      root@L503-sn101:/opt/fw# /opt/neuron-bin/fwserial -p /dev/extcomm/0/0 -PR
                      Firmware: v5.6
                      Modbus timeout set
                      Programming page 00 ...Finished programming chunk 0, ret: 64 err: 0
                      Finished programming chunk 1, ret: 64 err: 0
                      Finished programming chunk 2, ret: 64 err: 0
                      Finished programming chunk 3, ret: 64 err: 0
                      Finished programming chunk 4, ret: 64 err: 0
                      Finished programming chunk 5, ret: 64 err: 0
                      Finished programming chunk 6, ret: 64 err: 0
                      Finished programming chunk 7, ret: 64 err: 0
                      Page written OK.
                      Programming page 01 ...Finished programming chunk 0, ret: 64 err: 0
                      1. Verify the firmware. Since the flashed firmware now accepts address set by DIP switches, you need to specify the address in the parameter -u. My extension has address 3
                      root@L503-sn101:/opt/fw# /opt/neuron-bin/fwserial -p /dev/extcomm/0/0 -u 3
                      Firmware: v5.18
                      Modbus timeout set
                      1. Repeat the process for all of the extensions
                        Firmware is now 5.9 (it was 5.6 as you said), is there any need to upgrade to 5.18?
                          @bsc101 So I guess you used the Windows firmware update tool as @salorob. There are definitely a bugfixes from version 5.9 with some new functionality as well. You have the tutorial above, so you can update it, if you find out you need it.
                          B 2 Replies Last reply
                              @martin-kudláček My fault, did not do step 1 in your decsription above since fwserial and firmware files were already present. It's 5.18 now, thank you!
                              Reply Quote 1
                                Boy Lenssen
                                Ok, took a while before I had time to do this, but now the downloads don't seem to work anymore, check below (btw, I'm using an own build image, not the Neuron image):
                                root@L203-sn81:/home/pi# wget -O - https://files.unipi.technology/debian/unipi_pub.gpg | apt-key add\
                                > ^C
                                --2019-09-12 08:05:48--  https://files.unipi.technology/debian/unipi_pub.gpg
                                Resolving files.unipi.technology (files.unipi.technology)... 86.49.170.141
                                Connecting to files.unipi.technology (files.unipi.technology)|86.49.170.141|:443... connected.
                                HTTP request sent, awaiting response... 302 Found
                                Location: https://kb.unipi.technology/debian/unipi_pub.gpg [following]
                                --2019-09-12 08:05:49--  https://kb.unipi.technology/debian/unipi_pub.gpg
                                Resolving kb.unipi.technology (kb.unipi.technology)... 86.49.170.141
                                Connecting to kb.unipi.technology (kb.unipi.technology)|86.49.170.141|:443... connected.
                                HTTP request sent, awaiting response... 200 OK
                                Length: unspecified [text/html]
                                Saving to: 'STDOUT'
                                -                                                     [ <=>        ]  13.43K  --.-KB/s    in 0.03s
                                2019-09-12 08:05:49 (385 KB/s) - written to stdout [13757]
                                gpg: no valid OpenPGP data found.
                                root@L203-sn81:/home/pi# apt update
                                Get:1 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
                                Get:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB]
                                Get:3 http://raspbian.raspberrypi.org/raspbian stretch/contrib Sources [75.2 kB]
                                Get:5 http://raspbian.raspberrypi.org/raspbian stretch/non-free Sources [125 kB]
                                Get:6 http://archive.raspberrypi.org/debian stretch/main armhf Packages [221 kB]
                                Get:7 http://raspbian.raspberrypi.org/raspbian stretch/main Sources [9721 kB]
                                Get:8 http://archive.raspberrypi.org/debian stretch/ui armhf Packages [45.0 kB]
                                Err:4 https://kb.unipi.technology/debian stretch InRelease
                                  Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
                                Get:9 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages [11.7 MB]
                                Get:10 http://raspbian.raspberrypi.org/raspbian stretch/contrib armhf Packages [56.9 kB]
                                Get:11 http://raspbian.raspberrypi.org/raspbian stretch/non-free armhf Packages [95.5 kB]
                                Fetched 22.1 MB in 18s (1192 kB/s)
                                Reading package lists... Done
                                E: Failed to fetch https://files.unipi.technology/debian/dists/stretch/InRelease  Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
                                E: Some index files failed to download. They have been ignored, or old ones used instead.
                                root@L203-sn81:/home/pi# apt install -y neuron-firmware neuron-modbus-tools
                                Building dependency tree
                                Reading state information... Done
                                Note, selecting 'unipi-modbus-tools' instead of 'neuron-modbus-tools'
                                E: Unable to locate package neuron-firmware
                                root@L203-sn81:/home/pi# /opt/neuron-bin/fwserial -p /dev/extcomm/0/0
                                bash: /opt/neuron-bin/fwserial: No such file or directory
                                  Boy Lenssen
                                  So I tried with an official Unipian image, but still same problem. Some security issue (gpg: no valid OpenPGP data found). Please help @tomas_hora @Martin-Kudláček
                                    tomas_hora administrators
                                    The files has been moved into a new repostirory: https://repo.unipi.technology/debian/ The FW tool for extension can be found here https://kb.unipi.technology/files:software:tools:00-start#extension_firmware_update_tool
                                      Boy Lenssen
                                      Thanks! I was able to flash the device using the FW update tool and now it says it v5.36 on it.
                                      Too bad I'm not able to try it out now, as on my test Unipi I accidentally plugged in the power supply on the RS485 port and now I get
                                      root@L203-sn81:/home/pi# /opt/unipi-bin/fwserial -p /dev/extcomm/0/0
                                      Read version failed: Connection timed out
                                      Will need to get a new Neuron for this.
                                      Thanks for the help! :)
                                        tomas_hora administrators @Boy Lenssen
                                        @boy-lenssen Yeah, that's something we are working on to protect bricking the units during the FW upgrade process. If the RUN led is dead, send it to us so we can reflash the FW.
