    17534
      Martin Kudláček @salorob last edited by
      Hi @salorob,
      • on xS50, you can set only address by DIP switches. The DIP switch settings has to match the address parameter in evok.conf
      • The default serial line configuration of the extension is 19200bps, 8 data bits, no parity and 1 stop bit, so change the serial line settings in the EVOK accordingly.
      PS. And thanks for another hint - the default settings of EVOK should reflect the defaults of the extensions.
        salorob last edited by salorob
        Okay, changed some things to be precise like you say, but still no comms on none of the modules
        [EXTENSION_1]
        device_name = xS50                                              ; Mandatory
        neuron_uart_circuit = 1_01                              ; Optional, allows associating extensions with specific Neuron UART-over-Modbus ports (not possible for non-Modbus UART ports, e.g. /dev/ttyUSB0 or /dev/ttyS0)
        allow_register_access = True                    ; Optional, False default, is mandatory with third-party devices
        address = 1                                                     ; Optional, 1 default
        scan_frequency = 10                                    ; Optional, 10 default
        scan_enabled = True                                    ; Optional, True default
        baud_rate = 19200                                               ; Optional, NEEDS UNIPI IMAGE TO WORK! USE API TO CONFIGURE UART MANUALLY IF USING STANDARD RASPBIAN
        parity = N                                                              ; Optional, NEEDS UNIPI IMAGE TO WORK! USE API TO CONFIGURE UART MANUALLY IF USING STANDARD RASPBIAN
        stop_bits = 1                                                   ; Optional, NEEDS UNIPI IMAGE TO WORK! USE API TO CONFIGURE UART MANUALLY IF USING STANDARD RASPBIAN
        [EXTENSION_2]
        global_id = 3                                                   ; Mandatory, REQUIRED TO BE UNIQUE
        address = 2                                                     ; Optional, 1 default
        [EXTENSION_3]
        global_id = 4                                                   ; Mandatory, REQUIRED TO BE UNIQUE
        address = 3                                                     ; Optional, 1 default
        with these dip-switch settings:
        Dip-switches on modules:
        • xS50 #1 = 1 0 0 = EXTENSION_1, address = 1
        • xS50 #2 = 0 1 0 = EXTENSION_2, address = 2
        • xS50 #3 = 1 1 0 = EXTENSION_3, address = 3
        Please note they are al on the first UART: 1.1 - RS485. Does that make a difference?
        p.s. I used a default Raspbian stretch image (so not one of you're images), and used your install scripts like so:
        sudo su
        wget https://github.com/UniPiTechnology/evok/archive/v.2.0.7.zip
        unzip v.2.0.7.zip
        cd evok-v.2.0.7
        bash install-evok.sh
        Is that any problem?
          Martin Kudláček @salorob last edited by Martin Kudláček
          Let's investigate:
          • Did you restart the Neuron after changing the settings (or at least the evok service)?
          • what Raspbian image do you use ? Please, paste the output of the uname -a.
            We are probably (not confirmed, working on it) experiencing an issue with running the EVOK on the up-to-date Raspbian
          M.
          S 1 Reply Last reply Reply Quote 0
            salorob @Martin Kudláček last edited by
            @martin-kudláček
            • Yes; I'm very neurotic on that, I rebooted the L513, and made the extensions powerless also.
            • As for the version, I'm using the latest Debian, (downloaded it from the website last week?):
            Linux raspberrypi 4.14.50-v7+ #1122 SMP Tue Jun 19 12:26:26 BST 2018 armv7l GNU/Linux
              That seems to be OK. I will have to reproduce your setup, but I'm not sure, if I will be able to make it today. Tommorow morning for sure.
              M.
                Martin Kudláček last edited by Martin Kudláček
                OK, I partially reproduced your setup. I have:
                1. Neuron L503 with latest, up-to-date Raspbian (Linux raspberrypi 4.14.52-v7+ #1123 SMP Wed Jun 27 17:35:49 BST 2018 armv7l GNU/Linux), and EVOK 2.0.7. Serial line 1.1 configured with 19200bps, 8N1:
                1. One extension xS40 with address 3 (DIPs 3 and 4 are down):
                1. Another extension xS50 with address 2 (DIP 2 is up):
                1. Extensions and Neuron are connected with all RS485 "As" connected together and RS485 "Bs" connected together:
                1. The configuration in the evok.conf is this one:
                [MAIN]
                config_version = 2.5					; Configuration file version, DO NOT CHANGE!
                use_schema_verification = False			; Enabling this will deny any requests that do not match the JSON Schema; NOTE THAT THIS RESULTS IN A SIGNIFICANT INCREASE IN LATENCY AND SHOULD NOT BE USED EXCEPT FOR TESTING
                log_level = ERROR   					; Minimum severity of messages to be logged; one of INFO, DEBUG, WARNING, ERROR, CRITICAL
                log_file = /var/log/evok.log			; Log file to use; will be cleared on boot
                port = 8080								; !!! Internal API port - only change if you are certain you know what you are doing; FOR OUR WEB INTERFACE THE PORT SHOULD BE CHANGED IN "/etc/evok-nginx.conf" INSTEAD !!!
                webhook_enabled = False					; Enables webhook notification - see e.g. https://sendgrid.com/blog/whats-webhook/
                webhook_address = http://127.0.0.1:80   ; Put your server endpoint address here (e.g. http://123.123.123.123:/wh )
                webhook_device_mask = ["input","wd"]	; List of device types to notify on (written as a JSON list) - adding AI will generate a large amount of messages!
                webhook_complex_events = False			; EVOK will send POST requests with the same data as WebSocket, rather than an empty GET request
                wifi_control_enabled = False			; !!! REQUIRES THE UNIPIAP WIFI CONTROLLER TO BE INSTALLED !!! Will allow evok to control the internal Neuron wifi
                soap_server_enabled = False				; Enables the simple SOAP server; use only if you need the functionality
                soap_server_port = 8081					; !!! IF SOAP SERVER IS ENABLED, THIS PORT NEEDS TO BE UNIQUE (i.e. different from the port setting above) !!!
                [NEURON_1]
                global_id = 1							; Mandatory, REQUIRED TO BE UNIQUE
                allow_register_access = False 			; Optional, False default
                ; Below you can find examples for connecting devices over UART; first example is a Neuron extension while the second is a custom third-party device
                ; Devices sharing a port use the port settings of the first device on that port (baud rate, parity, stopbits)
                ; !!!Note that device_name has to match a filename in the /etc/hw_definitions directory!!! See /etc/hw_definitions/DOMAT MMIO.yaml for an example
                [EXTENSION_1]
                device_name = xS40						; Mandatory
                ;neuron_uart_circuit = 1_01				; Optional, allows associating extensions with specific Neuron UART-over-Modbus ports (not possible for non-Modbus UART ports, e.g. /dev/ttyUSB0 or /dev/ttyS0)
                ;allow_register_access = True 			; Optional, False default, is mandatory with third-party devices
                ;scan_frequency = 10 					; Optional, 10 default
                ;scan_enabled = True 					; Optional, True default
                ;baud_rate = 19200						; Optional, NEEDS UNIPI IMAGE TO WORK! USE API TO CONFIGURE UART MANUALLY IF USING STANDARD RASPBIAN
                ;parity = N								; Optional, NEEDS UNIPI IMAGE TO WORK! USE API TO CONFIGURE UART MANUALLY IF USING STANDARD RASPBIAN
                ;stop_bits = 1							; Optional, NEEDS UNIPI IMAGE TO WORK! USE API TO CONFIGURE UART MANUALLY IF USING STANDARD RASPBIAN
                [EXTENSION_2]
                ;[EXTENSION_2]
                ;global_id = 3							; Mandatory, REQUIRED TO BE UNIQUE
                ;device_name = CUSTOM MODBUS DEVICE		; Mandatory
                ;modbus_uart_port = /dev/extcomm/0/0 	; Mandatory
                ;allow_register_access = True 			; Mandatory with third-party devices
                ;address = 1 							; Optional, 15 default
                ;scan_frequency = 2 					; Optional, 1 default
                [OWBUS_1]
                owbus = /dev/i2c-1 --i2c=/dev/i2c-1:ALL     		; Scanned bus (--i2c=/dev/i2c-1:ALL or localhost:2122 or 'u' for USB dongle)
                interval = 3          					; [s] Default sensor reading
                scan_interval = 300    					; [s] How often is scanning done
                ;Example of 1W-4R/4DI extension module, 1W-8R is almost the same, only with inputs instead of relays
                ; - Setting the correct reading interval is crucial to achieve ideal performance; the default interval is 15s
                ;[1WDEVICE_2]
                ;bus = 1
                ;address = 29F39A17000000BC
                ;type = DS2408
                ;interval = 1
                ;[1WRELAY_10]
                ;sensor = 2
                ;pin = 0
                ;[1WRELAY_11]
                ;sensor = 2
                ;pin = 1
                ;[1WRELAY_12]
                ;sensor = 2
                ;pin = 2
                ;[1WRELAY_13]
                ;sensor = 2
                ;pin = 3
                ;[1WINPUT_20]
                ;sensor = 2
                ;pin = 4
                ;[1WINPUT_21]
                ;sensor = 2
                ;pin = 5
                ;[1WINPUT_22]
                ;sensor = 2
                ;pin = 6
                ;[1WINPUT_23]
                ;sensor = 2
                ;pin = 7
                1. After restarting the evok (service restart evok), the devices and their inputs/outputs were immediatelly available in the Web UI:
                0_1531147081348_FireShot Capture 1 - UniPi Control Panel - http___192.168.221.95_.png
                Can you check your setup against mine above? Try simplifying the extension's configuration as I did.
                M.
                  I wil have to check in a minute.
                  As far as I can remember from testing yesterday; even if I connect just 1 module, which I give a fixed address with the dipswitch (say; dip 1 = up, makes address = 1 (right?)), and configure the evok.conf accordingly, it won't work.
                  So in my opinion, setting an address manually by dip-switch, causes something to go wrong. Either I don't understand how the dip's represent an address, or something else goes haywire...
                  however; I didn't check with the ;neuron_uart_circuit = 1_01 commented like in your example, wil check that in a minute.
                  What does this option do anyway ?
                    So; another quick test:
                    • If I connect just 1 xS50, which I give a fixed address with the dipswitch (dip 1 = up, makes address = 1 (right?)), and configure the evok.conf accordingly, and configure the serial speed, it won't work.
                    • All dip's down, on evok address 15, it works.
                      this really seems to be an issue on our part, probably related to the firmware of the extensions. You are not the only one having the exactly same problem (see https://forum.unipi.technology/topic/652/how-to-add-xs40-to-neuron-l203-using-custom-software/42). We will investigate it a bit more and let you know as soon as possible.
                      Thank you for your patience,
                        Ah.. okay. Well, at least I'm not crazy.
                        Please let me know, I need to get this setup running asap.
                          ok, to get your setup running ASAP - would it be possible to use Teamviewer or direct SSH to the controller so we can check what's happening? We will check the extension's firmware version and do the FW update if neccessary.
                          The best time would be between 12:00 and 20:00 CEST.
                                bsc101 @Martin Kudláček last edited by
                                Boris
                                  Martin Kudláček @bsc101 last edited by
                                      Martin Kudláček @bsc101 last edited by Martin Kudláček
                                      1. SSH into your controller, the user "pi", the password (if not changed) is "raspberry". If your image is Raspbian, you need to install additional packages:
                                      pi@raspberrypi:~ $ sudo bash
                                      root@raspberrypi:/home/pi# echo "deb https://files.unipi.technology/debian stretch main" > /etc/apt/sources.list.d/unipi.list
                                      root@raspberrypi:/home/pi# wget -O - https://files.unipi.technology/debian/unipi_pub.gpg | apt-key add
                                      root@raspberrypi:/home/pi# apt update
                                      root@raspberrypi:/home/pi# apt install -y neuron-firmware neuron-modbus-tools
                                      1. Connect the extension to the controller over RS485. If you have multiple extensions, connect only one at a time. Right now, all of them thinks they have address 15, so you need to avoid collisions.
                                      2. Confirm, you have a connection to extension
                                      root@L503-sn101:/home/pi# /opt/neuron-bin/fwserial -p /dev/extcomm/0/0
                                      Boardset:     5 E-14Ro_P-11DiR485              (v1.0)
                                      Baseboard:    2 E-14Ro                         (v1.0)
                                      Firmware: v5.6
                                      Modbus timeout set
                                      1. Flash the firmware
                                      root@L503-sn101:/opt/fw# /opt/neuron-bin/fwserial -p /dev/extcomm/0/0 -PR
                                      Firmware: v5.6
                                      Modbus timeout set
                                      Programming page 00 ...Finished programming chunk 0, ret: 64 err: 0
                                      Finished programming chunk 1, ret: 64 err: 0
                                      Finished programming chunk 2, ret: 64 err: 0
                                      Finished programming chunk 3, ret: 64 err: 0
                                      Finished programming chunk 4, ret: 64 err: 0
                                      Finished programming chunk 5, ret: 64 err: 0
                                      Finished programming chunk 6, ret: 64 err: 0
                                      Finished programming chunk 7, ret: 64 err: 0
                                      Page written OK.
                                      Programming page 01 ...Finished programming chunk 0, ret: 64 err: 0
                                      1. Verify the firmware. Since the flashed firmware now accepts address set by DIP switches, you need to specify the address in the parameter -u. My extension has address 3
                                      root@L503-sn101:/opt/fw# /opt/neuron-bin/fwserial -p /dev/extcomm/0/0 -u 3
                                      Firmware: v5.18
                                      Modbus timeout set
                                      1. Repeat the process for all of the extensions
                                        Firmware is now 5.9 (it was 5.6 as you said), is there any need to upgrade to 5.18?
                                          @bsc101 So I guess you used the Windows firmware update tool as @salorob. There are definitely a bugfixes from version 5.9 with some new functionality as well. You have the tutorial above, so you can update it, if you find out you need it.
                                          B 2 Replies Last reply Reply Quote 0
                                            bsc101 @Martin Kudláček last edited by bsc101
