    29 Posts 5 Posters 18.3k Views 3 Watching
      salorob
        Martin Kudláček @salorob
          bsc101 @Martin Kudláček
          Boris
            Martin Kudláček @bsc101
            B 1 Reply Last reply
                1. SSH into your controller, the user "pi", the password (if not changed) is "raspberry". If your image is Raspbian, you need to install additional packages:
                pi@raspberrypi:~ $ sudo bash
                root@raspberrypi:/home/pi# echo "deb https://files.unipi.technology/debian stretch main" > /etc/apt/sources.list.d/unipi.list
                root@raspberrypi:/home/pi# wget -O - https://files.unipi.technology/debian/unipi_pub.gpg | apt-key add
                root@raspberrypi:/home/pi# apt update
                root@raspberrypi:/home/pi# apt install -y neuron-firmware neuron-modbus-tools
                1. Connect the extension to the controller over RS485. If you have multiple extensions, connect only one at a time. Right now, all of them thinks they have address 15, so you need to avoid collisions.
                2. Confirm, you have a connection to extension
                root@L503-sn101:/home/pi# /opt/neuron-bin/fwserial -p /dev/extcomm/0/0
                Boardset:     5 E-14Ro_P-11DiR485              (v1.0)
                Baseboard:    2 E-14Ro                         (v1.0)
                Firmware: v5.6
                Modbus timeout set
                1. Flash the firmware
                root@L503-sn101:/opt/fw# /opt/neuron-bin/fwserial -p /dev/extcomm/0/0 -PR
                Firmware: v5.6
                Modbus timeout set
                Programming page 00 ...Finished programming chunk 0, ret: 64 err: 0
                Finished programming chunk 1, ret: 64 err: 0
                Finished programming chunk 2, ret: 64 err: 0
                Finished programming chunk 3, ret: 64 err: 0
                Finished programming chunk 4, ret: 64 err: 0
                Finished programming chunk 5, ret: 64 err: 0
                Finished programming chunk 6, ret: 64 err: 0
                Finished programming chunk 7, ret: 64 err: 0
                Page written OK.
                Programming page 01 ...Finished programming chunk 0, ret: 64 err: 0
                1. Verify the firmware. Since the flashed firmware now accepts address set by DIP switches, you need to specify the address in the parameter -u. My extension has address 3
                root@L503-sn101:/opt/fw# /opt/neuron-bin/fwserial -p /dev/extcomm/0/0 -u 3
                Firmware: v5.18
                Modbus timeout set
                1. Repeat the process for all of the extensions
                  Firmware is now 5.9 (it was 5.6 as you said), is there any need to upgrade to 5.18?
                    @bsc101 So I guess you used the Windows firmware update tool as @salorob. There are definitely a bugfixes from version 5.9 with some new functionality as well. You have the tutorial above, so you can update it, if you find out you need it.
                    B 2 Replies Last reply
                        @martin-kudláček My fault, did not do step 1 in your decsription above since fwserial and firmware files were already present. It's 5.18 now, thank you!
                        Reply Quote 1
                          Boy Lenssen
                          Ok, took a while before I had time to do this, but now the downloads don't seem to work anymore, check below (btw, I'm using an own build image, not the Neuron image):
                          root@L203-sn81:/home/pi# wget -O - https://files.unipi.technology/debian/unipi_pub.gpg | apt-key add\
                          > ^C
                          --2019-09-12 08:05:48--  https://files.unipi.technology/debian/unipi_pub.gpg
                          Resolving files.unipi.technology (files.unipi.technology)... 86.49.170.141
                          Connecting to files.unipi.technology (files.unipi.technology)|86.49.170.141|:443... connected.
                          HTTP request sent, awaiting response... 302 Found
                          Location: https://kb.unipi.technology/debian/unipi_pub.gpg [following]
                          --2019-09-12 08:05:49--  https://kb.unipi.technology/debian/unipi_pub.gpg
                          Resolving kb.unipi.technology (kb.unipi.technology)... 86.49.170.141
                          Connecting to kb.unipi.technology (kb.unipi.technology)|86.49.170.141|:443... connected.
                          HTTP request sent, awaiting response... 200 OK
                          Length: unspecified [text/html]
                          Saving to: 'STDOUT'
                          -                                                     [ <=>        ]  13.43K  --.-KB/s    in 0.03s
                          2019-09-12 08:05:49 (385 KB/s) - written to stdout [13757]
                          gpg: no valid OpenPGP data found.
                          root@L203-sn81:/home/pi# apt update
                          Get:1 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
                          Get:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB]
                          Get:3 http://raspbian.raspberrypi.org/raspbian stretch/contrib Sources [75.2 kB]
                          Get:5 http://raspbian.raspberrypi.org/raspbian stretch/non-free Sources [125 kB]
                          Get:6 http://archive.raspberrypi.org/debian stretch/main armhf Packages [221 kB]
                          Get:7 http://raspbian.raspberrypi.org/raspbian stretch/main Sources [9721 kB]
                          Get:8 http://archive.raspberrypi.org/debian stretch/ui armhf Packages [45.0 kB]
                          Err:4 https://kb.unipi.technology/debian stretch InRelease
                            Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
                          Get:9 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages [11.7 MB]
                          Get:10 http://raspbian.raspberrypi.org/raspbian stretch/contrib armhf Packages [56.9 kB]
                          Get:11 http://raspbian.raspberrypi.org/raspbian stretch/non-free armhf Packages [95.5 kB]
                          Fetched 22.1 MB in 18s (1192 kB/s)
                          Reading package lists... Done
                          E: Failed to fetch https://files.unipi.technology/debian/dists/stretch/InRelease  Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
                          E: Some index files failed to download. They have been ignored, or old ones used instead.
                          root@L203-sn81:/home/pi# apt install -y neuron-firmware neuron-modbus-tools
                          Building dependency tree
                          Reading state information... Done
                          Note, selecting 'unipi-modbus-tools' instead of 'neuron-modbus-tools'
                          E: Unable to locate package neuron-firmware
                          root@L203-sn81:/home/pi# /opt/neuron-bin/fwserial -p /dev/extcomm/0/0
                          bash: /opt/neuron-bin/fwserial: No such file or directory
                            Boy Lenssen
                            So I tried with an official Unipian image, but still same problem. Some security issue (gpg: no valid OpenPGP data found). Please help @tomas_hora @Martin-Kudláček
                              tomas_hora administrators
                              The files has been moved into a new repostirory: https://repo.unipi.technology/debian/ The FW tool for extension can be found here https://kb.unipi.technology/files:software:tools:00-start#extension_firmware_update_tool
                                Boy Lenssen
                                Thanks! I was able to flash the device using the FW update tool and now it says it v5.36 on it.
                                Too bad I'm not able to try it out now, as on my test Unipi I accidentally plugged in the power supply on the RS485 port and now I get
                                root@L203-sn81:/home/pi# /opt/unipi-bin/fwserial -p /dev/extcomm/0/0
                                Read version failed: Connection timed out
                                Will need to get a new Neuron for this.
                                Thanks for the help! :)
                                  tomas_hora administrators @Boy Lenssen
                                  @boy-lenssen Yeah, that's something we are working on to protect bricking the units during the FW upgrade process. If the RUN led is dead, send it to us so we can reflash the FW.
