    S103-G use GSM/GPRS module to connect to internet
    29 Posts 6 Posters 22.8k Views 2 Watching
    • U
      unix
      Hi
      i have inport your data but i get one error in debug
      its "3.11.2017, 10:59:29node: parseModelIDfunction : (error)
      "TypeError: Cannot read property 'trim' of undefined""
      and the website looks like :
      Daschboard
      connect is green but no info i have only change the serial connect to
      /dev/ttyAMA0: 115200-8n1
      or i have problems whit the modem i can send the first sms whitout problems but after this only error when i test it whit cu -l /dev/ttyAMA0
      hope for hints :smile:
      Regards
      roberts_landoR 1 Reply Last reply
      • roberts_landoR
        roberts_lando @unix
        @unix Did you close the connection after using cu? Cause that error means that I call .trim() in an undefined var (modelID) that means no data is received after the command. Each command has a timeout, after that I close the read stream from the serial and I try to parse the response string, if the response string is not well parsed those errors are normal, try to put a debug node to see the output of the serial and check that the cu session is closed.
        Disconnect: type ~ (alt+126) than wait for [unipi] output than type . and hit <Enter>
        • U
          unix
          Hi
          yes the cu session a closed in debug i see this
          3.11.2017, 11:25:11node: 96ac4186.358femsg.payload : string[4]
          "OK↵"
          3.11.2017, 11:25:13node: 96ac4186.358femsg.payload : string[11]
          "AT+COPS? ↵"
          3.11.2017, 11:25:13node: 96ac4186.358femsg.payload : string[17]
          "+COPS: 0,0,"A1"↵"
          3.11.2017, 11:25:13node: 96ac4186.358femsg.payload : string[2]
          3.11.2017, 11:25:13node: 96ac4186.358femsg.payload : string[4]
          "OK↵"
          3.11.2017, 11:25:14node: parseOperatorfunction : (error)
          3.11.2017, 11:25:15node: 96ac4186.358femsg.payload : string[10]
          "AT+CGMI ↵"
          3.11.2017, 11:25:15node: 96ac4186.358femsg.payload : string[18]
          "+CGMI: "Fibocom"↵"
          3.11.2017, 11:25:15node: 96ac4186.358femsg.payload : string[2]
          3.11.2017, 11:25:15node: 96ac4186.358femsg.payload : string[4]
          "OK↵"
          3.11.2017, 11:25:17node: 96ac4186.358femsg.payload : string[10]
          "AT+CGMM ↵"
          3.11.2017, 11:25:17node: 96ac4186.358femsg.payload : string[38]
          "+CGMM: "GSM850/900/1800/1900","G510"↵"
          3.11.2017, 11:25:17node: 96ac4186.358femsg.payload : string[2]
          3.11.2017, 11:25:17node: 96ac4186.358femsg.payload : string[4]
          "OK↵"
          3.11.2017, 11:25:18node: parseModelIDfunction : (error)
          Regards
          • roberts_landoR
            roberts_lando @unix
            @unix I haven't the possibility to debug it right now, as your debug shows the commands are correctly received, I think you have to change the serial in-out configuration. Check it and send me a screenshot of both.
            Also try to put a debug node after join node wired with serial-out
            U 1 Reply Last reply
            • U
              unix @roberts_lando
              @roberts_lando
              i have found one error in another flow i have running sms sender i have delete this and the error seems only the trim see screenshots.
              1 alt text
              2 alt text
              3 alt text
              Regards
              i have check the modem connect over cu and modem works and i disconnect to the modem.
              • roberts_landoR
                roberts_lando @unix
                @unix ok I have found the problem: replace \n with \r\n in both serial-in and serial-out nodes than it should work correctly! This has happen because when you have imported the flow I think you haven't already installed node-red-node-serial and the configuration got lost
                • U
                  unix @roberts_lando
                  @roberts_lando
                  WTF great thx for fast response and help :smile:
                  regards
                  • roberts_landoR
                    roberts_lando @unix
                    @unix you welcome! :)
                    • Vesa KauppinenV
                      Vesa Kauppinen @roberts_lando
                      @roberts_lando said in S103-G use GSM/GPRS module to connect to internet:
                      Hi!
                      Great tutorial!
                      I use Raspbian Stretch Lite and I can not get the S103-G to work with these instructions. The command cu -l / dev / ttyAMA0 crashes when I try to AT command. Ifconfig does not give ppp0.
                      What have I missed?
                      Vesa
                      • U
                        unix @Vesa Kauppinen
                        @Vesa-Kauppinen
                        Hi
                        have you disable the BT on Pi3
                        /boot/config.txt addline
                        dtoverlay=pi3-disable-bt
                        and on /boot/cmdline.txt remove
                        serial console than its looks like
                        dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=e13fdf55-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                        Regards
                        Vesa KauppinenV 1 Reply Last reply
                        • Vesa KauppinenV
                          Vesa Kauppinen @unix
                          @unix
                          Thank you for answer!
                          BT disabled and cmdline.txt edited...
                          No success
                          @tomas_hora any ideas?
                          Vesa
                          • roberts_landoR
                            roberts_lando
                            I always had compatibility problems when using Raspbian Stretch, try to use last Raspbian Jessie img and it should work
                            • Vesa KauppinenV
                              @roberts_lando
                              Now i have tried with Rasbian Jessie Lite.....no success :disappointed:
                              Do you use Jessie Lite or full?
                              Vesa
                              • roberts_landoR
                                roberts_lando @Vesa Kauppinen
                                @Vesa-Kauppinen I think you have missed one or more step of the turorial. I suggest you to retry the tutorial and check if an instruction fails. Do you have switch on the GPRS module?
                                  mattia98 @roberts_lando
                                  @roberts_lando Hi, I've done all the steps to configure the internet connection but when I type "ifconfig" it doesn't show me the ppp0 interface. Could you please help me?
                                  when I type the command "cat /var/log/syslog" It show me this messages:
                                  Sep 4 13:41:52 raspberrypi pppd[1698]: pppd 2.4.7 started by root, uid 0
                                  Sep 4 13:41:52 raspberrypi chat[1702]: abort on (BUSY)
                                  Sep 4 13:41:52 raspberrypi chat[1702]: abort on (VOICE)
                                  Sep 4 13:41:52 raspberrypi chat[1702]: abort on (NO CARRIER)
                                  Sep 4 13:41:52 raspberrypi chat[1702]: abort on (NO DIALTONE)
                                  Sep 4 13:41:52 raspberrypi chat[1702]: abort on (NO DIAL TONE)
                                  Sep 4 13:41:52 raspberrypi chat[1702]: abort on (NO ANSWER)
                                  Sep 4 13:41:52 raspberrypi chat[1702]: abort on (DELAYED)
                                  Sep 4 13:41:52 raspberrypi chat[1702]: abort on (ERROR)
                                  Sep 4 13:41:52 raspberrypi chat[1702]: abort on (+CGATT: 0)
                                  Sep 4 13:41:52 raspberrypi chat[1702]: send (AT^M)
                                  Sep 4 13:41:52 raspberrypi chat[1702]: timeout set to 12 seconds
                                  Sep 4 13:41:52 raspberrypi chat[1702]: expect (OK)
                                  Sep 4 13:42:04 raspberrypi chat[1702]: alarm
                                  Sep 4 13:42:04 raspberrypi chat[1702]: Failed
                                  Sep 4 13:42:04 raspberrypi pppd[1698]: Connect script failed
                                  Sep 4 13:42:10 raspberrypi OWFS[477]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
                                  Sep 4 13:42:30 raspberrypi OWFS[477]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
                                    tomas_hora administrators
                                    The issue was by the incorrect comm speed with the modem. I modified the guide provided by @roberts_lando to use the proper baudrate of 9600 instead of 115200.
