    S103-G use GSM/GPRS module to connect to internet
    29 Posts 6 Posters 22.8k Views 2 Watching
    • roberts_landoR
      roberts_lando
      Thanks @tomas_hora I did it now! If you want I can make a full tutorial about this topic
      • roberts_landoR
        roberts_lando
        TUTORIAL FIBOCOM G510 Unipi Neuron S103-G
        Make the file-system writable:
        mount / -o remount,rw
        mount /boot -o remount,rw
        Test the interface /dev/ttyAMA0 (serial link parameters: 115 200 1N8 Bps/Par/Bits)
        1. Export pin 18
        echo 18 >/sys/class/gpio/export
        1. Switch on module
        echo out > /sys/class/gpio/gpio18/direction
        echo 1 > /sys/class/gpio/gpio18/value
        echo 0 > /sys/class/gpio/gpio18/value
        sleep 1
        sleep 2
        1. Start the communication using cu
        apt-get install cu
        chown root:root /dev/ttyAMA0
        cu -l /dev/ttyAMA0
        1. Test: send sms (<Enter> means you have to press enter, OK is the output of the command)
        AT  <Enter>
        OK
        AT+CMGF=1 <Enter>
        OK
        AT+CMGS="yourphonenumber" <Enter>
        > Prova  <Ctrl+z>
        +CMGS: 152
        OK
        1. Disconnect: type ~ (alt+126) than wait for [unipi] output than type . and hit <Enter>
        ~[unipi]. <Enter>
        If interface doesn't works try:
        1. Enable UART: nano /boot/cmdline.txt add (if not present) or edit this line: enable_uart=1. Close and save the file by typing Ctrl+X and Y. Reboot Unipi Neuron and retry to test the interface.
        Now let's configure the interface for internet connection
        1. Install required packages
        apt-get update
        apt-get install ppp screen elinks
        1. Edit the configuration file (I use nano apt-get install nano)
        cd /etc/ppp/peers/
        nano rnet
        1. Copy the code below to the new file
        #configure for connection
        connect "/usr/sbin/chat -v -f /etc/chatscripts/gprs -T <yourAPNhere>"
        # Use /dev/ttyAMA0 as the communication port:
        /dev/ttyAMA0
        # Baudrate
        9600
        # Assumes that your IP address is allocated dynamically by the ISP.
        noipdefault
        # Try to get the name server addresses from the ISP.
        usepeerdns
        # Use this connection as the default route to the internet.
        defaultroute
        # Makes PPPD "dial again" when the connection is lost.
        persist
        # Do not ask the remote to authenticate.
        noauth
        # No hardware flow control on the serial link with GSM Modem
        nocrtscts
        # No modem control lines with GSM Modem
        local
        1. Replace <yourAPNhere> with your APN (Search in google APN of "your mobile operator") close and save the file by typing Ctrl+X and Y
        2. If your SIM card has a PIN edit this file nano /etc/chatscripts/gprs un comment the line AT+CPIN=1234 and set the pin instead of 1234
        3. Enable the connection by typing pon rnet. The show the log for PPPD type cat /var/log/syslog | grep pppd it will show if connection is established successfully.
        4. Type ifconfig, now you should see another interface named ppp0.
        0_1507015540134_upload-6607adf9-72d1-4cc9-97e2-cbe5b291b1c7
        1. To close the connection type poff rnet
        T Vesa KauppinenV M 3 Replies Last reply
          tomas_hora administrators @roberts_lando
          @roberts_lando Great! Thanks a lot!
          • roberts_landoR
            roberts_lando
            @tomas_hora Just made a node-red Dashboard to get Modem Data :)
            0_1507124912843_upload-f44d0f00-3612-47f8-aa08-91819d6ff5fe
            0_1507124782319_upload-8a2171eb-31ce-403a-8b88-428e8162c1b4
            With MNC MCC CellID and LAC it is also possible to get the location of the device by using https://opencellid.org/ APIs
            U 1 Reply Last reply
            • O
              oho
              Re: S103-G use GSM/GPRS module to connect to internet
              Does anyone know if it's possible to send AT commands from Mervis after turning on the modem first? Thanks.
                tomas_hora administrators @oho
                @oho Support of the GSM functionality will be available in Mervis in the next release.
                • U
                  unix @roberts_lando
                  @roberts_lando hi iam new in node-red and S103-g my question is can you share your nice looking flow to learn better node-red.
                  regards
                  • roberts_landoR
                    roberts_lando
                    @unix I have added it to node-red flows library: https://flows.nodered.org/flow/af6487676bd89e5e8b74b2c9da1e176d
                    Enjoy :)
                    • U
                      unix
                      Nice thx for help :smile:
                      Regards
                      • U
                        unix
                        Hi
                        i have inport your data but i get one error in debug
                        its "3.11.2017, 10:59:29node: parseModelIDfunction : (error)
                        "TypeError: Cannot read property 'trim' of undefined""
                        and the website looks like :
                        Daschboard
                        connect is green but no info i have only change the serial connect to
                        /dev/ttyAMA0: 115200-8n1
                        or i have problems whit the modem i can send the first sms whitout problems but after this only error when i test it whit cu -l /dev/ttyAMA0
                        hope for hints :smile:
                        Regards
                        roberts_landoR 1 Reply Last reply
                        • roberts_landoR
                          roberts_lando @unix
                          @unix Did you close the connection after using cu? Cause that error means that I call .trim() in an undefined var (modelID) that means no data is received after the command. Each command has a timeout, after that I close the read stream from the serial and I try to parse the response string, if the response string is not well parsed those errors are normal, try to put a debug node to see the output of the serial and check that the cu session is closed.
                          • U
                            unix
                            Hi
                            yes the cu session a closed in debug i see this
                            3.11.2017, 11:25:11node: 96ac4186.358femsg.payload : string[4]
                            "OK↵"
                            3.11.2017, 11:25:13node: 96ac4186.358femsg.payload : string[11]
                            "AT+COPS? ↵"
                            3.11.2017, 11:25:13node: 96ac4186.358femsg.payload : string[17]
                            "+COPS: 0,0,"A1"↵"
                            3.11.2017, 11:25:13node: 96ac4186.358femsg.payload : string[2]
                            3.11.2017, 11:25:13node: 96ac4186.358femsg.payload : string[4]
                            "OK↵"
                            3.11.2017, 11:25:14node: parseOperatorfunction : (error)
                            3.11.2017, 11:25:15node: 96ac4186.358femsg.payload : string[10]
                            "AT+CGMI ↵"
                            3.11.2017, 11:25:15node: 96ac4186.358femsg.payload : string[18]
                            "+CGMI: "Fibocom"↵"
                            3.11.2017, 11:25:15node: 96ac4186.358femsg.payload : string[2]
                            3.11.2017, 11:25:15node: 96ac4186.358femsg.payload : string[4]
                            "OK↵"
                            3.11.2017, 11:25:17node: 96ac4186.358femsg.payload : string[10]
                            "AT+CGMM ↵"
                            3.11.2017, 11:25:17node: 96ac4186.358femsg.payload : string[38]
                            "+CGMM: "GSM850/900/1800/1900","G510"↵"
                            3.11.2017, 11:25:17node: 96ac4186.358femsg.payload : string[2]
                            3.11.2017, 11:25:17node: 96ac4186.358femsg.payload : string[4]
                            "OK↵"
                            3.11.2017, 11:25:18node: parseModelIDfunction : (error)
                            Regards
                            • roberts_landoR
                              roberts_lando @unix
                              @unix I haven't the possibility to debug it right now, as your debug shows the commands are correctly received, I think you have to change the serial in-out configuration. Check it and send me a screenshot of both.
                              Also try to put a debug node after join node wired with serial-out
                              • U
                                unix @roberts_lando
                                @roberts_lando
                                i have found one error in another flow i have running sms sender i have delete this and the error seems only the trim see screenshots.
                                1 alt text
                                2 alt text
                                3 alt text
                                Regards
                                i have check the modem connect over cu and modem works and i disconnect to the modem.
                                • roberts_landoR
                                  roberts_lando @unix
                                  @unix ok I have found the problem: replace \n with \r\n in both serial-in and serial-out nodes than it should work correctly! This has happen because when you have imported the flow I think you haven't already installed node-red-node-serial and the configuration got lost
                                  • U
                                    unix @roberts_lando
                                    @roberts_lando
                                    WTF great thx for fast response and help :smile:
                                    regards
                                    • roberts_landoR
                                      roberts_lando @unix
                                      @unix you welcome! :)
                                      • Vesa KauppinenV
                                        Vesa Kauppinen @roberts_lando
                                        @roberts_lando said in S103-G use GSM/GPRS module to connect to internet:
                                        Hi!
                                        Great tutorial!
                                        I use Raspbian Stretch Lite and I can not get the S103-G to work with these instructions. The command cu -l / dev / ttyAMA0 crashes when I try to AT command. Ifconfig does not give ppp0.
                                        What have I missed?
                                        Vesa
                                        • U
                                          unix @Vesa Kauppinen
                                          @Vesa-Kauppinen
                                          Hi
                                          have you disable the BT on Pi3
                                          /boot/config.txt addline
                                          dtoverlay=pi3-disable-bt
                                          and on /boot/cmdline.txt remove
                                          serial console than its looks like
                                          dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=e13fdf55-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                                          Regards
                                          Vesa KauppinenV 1 Reply Last reply
                                          • Vesa KauppinenV
                                            Vesa Kauppinen @unix
                                            @unix
                                            Thank you for answer!
                                            BT disabled and cmdline.txt edited...
                                            No success
                                            @tomas_hora any ideas?
                                            Vesa
