    S103-G use GSM/GPRS module to connect to internet
    22286
    • roberts_lando
      roberts_lando last edited by roberts_lando
      @tomas_hora Just made a node-red Dashboard to get Modem Data :)
      0_1507124912843_upload-f44d0f00-3612-47f8-aa08-91819d6ff5fe
      0_1507124782319_upload-8a2171eb-31ce-403a-8b88-428e8162c1b4
      With MNC MCC CellID and LAC it is also possible to get the location of the device by using https://opencellid.org/ APIs
      U 1 Reply Last reply Reply Quote 0
      • O
        oho last edited by
        Re: S103-G use GSM/GPRS module to connect to internet
        Does anyone know if it's possible to send AT commands from Mervis after turning on the modem first? Thanks.
          tomas_hora administrators @oho last edited by
          @oho Support of the GSM functionality will be available in Mervis in the next release.
          • U
            unix @roberts_lando last edited by
            @roberts_lando hi iam new in node-red and S103-g my question is can you share your nice looking flow to learn better node-red.
            regards
            • roberts_lando
              @unix I have added it to node-red flows library: https://flows.nodered.org/flow/af6487676bd89e5e8b74b2c9da1e176d
              Enjoy :)
              • U
                unix last edited by
                Nice thx for help :smile:
                Regards
                • U
                  unix last edited by
                  Hi
                  i have inport your data but i get one error in debug
                  its "3.11.2017, 10:59:29node: parseModelIDfunction : (error)
                  "TypeError: Cannot read property 'trim' of undefined""
                  and the website looks like :
                  Daschboard
                  connect is green but no info i have only change the serial connect to
                  /dev/ttyAMA0: 115200-8n1
                  or i have problems whit the modem i can send the first sms whitout problems but after this only error when i test it whit cu -l /dev/ttyAMA0
                  hope for hints :smile:
                  Regards
                  roberts_lando 1 Reply Last reply Reply Quote 0
                  • roberts_lando
                    roberts_lando @unix last edited by roberts_lando
                    @unix Did you close the connection after using cu? Cause that error means that I call .trim() in an undefined var (modelID) that means no data is received after the command. Each command has a timeout, after that I close the read stream from the serial and I try to parse the response string, if the response string is not well parsed those errors are normal, try to put a debug node to see the output of the serial and check that the cu session is closed.
                    Disconnect: type ~ (alt+126) than wait for [unipi] output than type . and hit <Enter>
                    • U
                      unix last edited by
                      Hi
                      yes the cu session a closed in debug i see this
                      3.11.2017, 11:25:11node: 96ac4186.358femsg.payload : string[4]
                      "OK↵"
                      3.11.2017, 11:25:13node: 96ac4186.358femsg.payload : string[11]
                      "AT+COPS? ↵"
                      3.11.2017, 11:25:13node: 96ac4186.358femsg.payload : string[17]
                      "+COPS: 0,0,"A1"↵"
                      3.11.2017, 11:25:13node: 96ac4186.358femsg.payload : string[2]
                      3.11.2017, 11:25:13node: 96ac4186.358femsg.payload : string[4]
                      "OK↵"
                      3.11.2017, 11:25:14node: parseOperatorfunction : (error)
                      3.11.2017, 11:25:15node: 96ac4186.358femsg.payload : string[10]
                      "AT+CGMI ↵"
                      3.11.2017, 11:25:15node: 96ac4186.358femsg.payload : string[18]
                      "+CGMI: "Fibocom"↵"
                      3.11.2017, 11:25:15node: 96ac4186.358femsg.payload : string[2]
                      3.11.2017, 11:25:15node: 96ac4186.358femsg.payload : string[4]
                      "OK↵"
                      3.11.2017, 11:25:17node: 96ac4186.358femsg.payload : string[10]
                      "AT+CGMM ↵"
                      3.11.2017, 11:25:17node: 96ac4186.358femsg.payload : string[38]
                      "+CGMM: "GSM850/900/1800/1900","G510"↵"
                      3.11.2017, 11:25:17node: 96ac4186.358femsg.payload : string[2]
                      3.11.2017, 11:25:17node: 96ac4186.358femsg.payload : string[4]
                      "OK↵"
                      3.11.2017, 11:25:18node: parseModelIDfunction : (error)
                      Regards
                      • roberts_lando
                        @unix I haven't the possibility to debug it right now, as your debug shows the commands are correctly received, I think you have to change the serial in-out configuration. Check it and send me a screenshot of both.
                        Also try to put a debug node after join node wired with serial-out
                        • U
                          @roberts_lando
                          i have found one error in another flow i have running sms sender i have delete this and the error seems only the trim see screenshots.
                          1 alt text
                          2 alt text
                          3 alt text
                          Regards
                          i have check the modem connect over cu and modem works and i disconnect to the modem.
                          • roberts_lando
                            @unix ok I have found the problem: replace \n with \r\n in both serial-in and serial-out nodes than it should work correctly! This has happen because when you have imported the flow I think you haven't already installed node-red-node-serial and the configuration got lost
                            • U
                              @roberts_lando
                              WTF great thx for fast response and help :smile:
                              regards
                              • roberts_lando
                                @unix you welcome! :)
                                • Vesa Kauppinen
                                  Vesa Kauppinen @roberts_lando last edited by
                                  @roberts_lando said in S103-G use GSM/GPRS module to connect to internet:
                                  Hi!
                                  Great tutorial!
                                  I use Raspbian Stretch Lite and I can not get the S103-G to work with these instructions. The command cu -l / dev / ttyAMA0 crashes when I try to AT command. Ifconfig does not give ppp0.
                                  What have I missed?
                                  Vesa
                                  • U
                                    unix @Vesa Kauppinen last edited by
                                    @Vesa-Kauppinen
                                    Hi
                                    have you disable the BT on Pi3
                                    /boot/config.txt addline
                                    dtoverlay=pi3-disable-bt
                                    and on /boot/cmdline.txt remove
                                    serial console than its looks like
                                    dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=e13fdf55-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                                    Regards
                                    Vesa Kauppinen 1 Reply Last reply Reply Quote 0
                                    • Vesa Kauppinen
                                      Vesa Kauppinen @unix last edited by
                                      @unix
                                      Thank you for answer!
                                      BT disabled and cmdline.txt edited...
                                      No success
                                      @tomas_hora any ideas?
                                      Vesa
                                      • roberts_lando
                                        I always had compatibility problems when using Raspbian Stretch, try to use last Raspbian Jessie img and it should work
                                        • Vesa Kauppinen
                                          Vesa Kauppinen @roberts_lando last edited by Vesa Kauppinen
                                          @roberts_lando
                                          Now i have tried with Rasbian Jessie Lite.....no success :disappointed:
                                          Do you use Jessie Lite or full?
                                          Vesa
                                          • roberts_lando
                                            roberts_lando @Vesa Kauppinen last edited by
                                            @Vesa-Kauppinen I think you have missed one or more step of the turorial. I suggest you to retry the tutorial and check if an instruction fails. Do you have switch on the GPRS module?
