    Control RO with Direct switch by Mervis
    3702
      Martin Trojan last edited by
      I have controled light on RO, it is connected with wall button with DirectSwitch functionality. I want control RO from Mervis as well but it does not work. How can I do it?
        tomas_hora administrators @Martin Trojan last edited by
        @martin-trojan Please check DirectSwitch_force from the Lib.UniPi
          Martin Trojan last edited by Martin Trojan
          Hello, it works.
          I want control light from web(digital setter) and HW button with direct switch. But I dont know how to create this funcionality. My solution blinking the lights and I am succesfull to turn on/off lights after 2-3 attempts. Can someone help me?
            Can @tomas_hora recommend how to setup web button when it is swithed by hw button to match the current state of light and not swich at the same time?
              Martin Kudláček @Martin Trojan last edited by
              Hello @martin-trojan, this isn't as easy as it looks like. We are preparing a solution as we speak and we will get back to you as soon as possible.
              Thanks for your patience,
                @Martin-Kudláček any progress?
                  Hi @Martin-Trojan,
                  This is just one possible solution, but you can use a custom ST FunctionBlock with this code (use the name "DigitalMemoryMultiplexer" if you do use it):
                  FUNCTION_BLOCK DigitalMemoryMultiplexer
                  EXTENDS //base type
                  IMPLEMENTS //interface type list
                  	VAR
                  		previous_inp_1: BOOL;
                  		previous_inp_2: BOOL;
                  		previous_outp: BOOL;
                  	END_VAR
                  	VAR_INPUT
                  		inp1: BOOL;
                  		inp2: BOOL;
                  	END_VAR
                  	VAR_OUTPUT
                  		outp: BOOL;
                  	END_VAR
                  	INIT
                  		previous_inp_1 := inp1;
                  		previous_inp_2 := inp2;
                  		previous_outp := inp1;
                  	END_INIT
                  	IF inp1 <> previous_inp_1 THEN
                  		outp := inp1;
                  	ELSIF inp2 <> previous_inp_2 THEN
                  		outp := inp2;
                  	ELSE
                  		outp := previous_outp;
                  	END_IF;
                  	previous_outp := outp;
                  END_FUNCTION_BLOCK
                  And connect it like this:
                  alt text
                  The DO_2_01 is set as DirectSwitch Trigger and the WEB_LIGHT_BUTTON is tied to a HMI Digital Setter. Whenever you are using DirectSwitch remember to set the Debounce value on the DI sufficiently high for your input device.
                  Again, there are many other options for doing this, including using two HMI elements on top of each other (Digital Indicator and Digital Setter).
                  Here is the project file, for reference: https://www.mediafire.com/file/1o8kq9iici2qc8g/ForumProject.7z/file
