    Modbus RTU slave device not communicating
    • G
      GrahamCC last edited by
      I am having trouble getting a modbus slave to communicate with a Unipi Neuron.
      The slave unit is a Parker inverter drive.
      I have been trying to read a single holding register:
      slave address 01
      function code 03
      read offset 1004
      I can read the register fine using a different device (programmed via codesys) but the unipi does not seem to be getting a response.
      I am writing '13' to 'Neuron S10x_UART_config_1.01' to set baud at 9600
      Watching the port monitor shows the sent message looks correct but it times out with no response. the timeout is set to 1000ms.
      Any ideas?
      • P
        pascal @GrahamCC last edited by
        Hi
        @GrahamCC
        I am having the same trouble.
        Could you find a solution for this problem?
          tomas_hora administrators @pascal last edited by
          Hello @pascal and @GrahamCC,
          please check the latest step by step manual for RS485 guide. Make sure to also check the parity (which must be set through the uart_config variable)
          • P
            pascal @tomas_hora last edited by
            @tomas_hora where can i find this manual?
            Parity is set correct.
              @pascal http://downloads.unipi.technology SW-Mervis
