Cannot uprgrading firmware
When I run the command/opt/unipi/tools/fwspi -i 0
I get this error
ARMINIT: Cannot open device /dev/unipispi
Unable to create the arm[0] context
What can I do? Thanksthat's my disto:
Linux L203-sn121 6.6.31-v8 #1 SMP PREEMPT Fri Jun 28 10:02:55 UTC 2024 aarch64 -
@paolo
Two issues there:- You need to run the command as root (with sudo)
- -i parameter is not valid for unipi-kernel-modules >= 2.0, you need to use the -u parameter, see help with --help.
