    Cannot uprgrading firmware
      paolo last edited by paolo
      When I run the command /opt/unipi/tools/fwspi -i 0 I get this error
      ARMINIT: Cannot open device /dev/unipispi
      Unable to create the arm[0] context
      What can I do? Thanks
      that's my disto:
      Linux L203-sn121 6.6.31-v8 #1 SMP PREEMPT Fri Jun 28 10:02:55 UTC 2024 aarch64
        cleve administrators @paolo last edited by
        @paolo
        Two issues there:
        • You need to run the command as root (with sudo)
        • -i parameter is not valid for unipi-kernel-modules >= 2.0, you need to use the -u parameter, see help with --help.
          paolo @cleve last edited by paolo
          @cleve Thank you very much, but I don't understand what I should do next...
          here's what I did:
          unipi@L203-sn121:~$ sudo /opt/unipi/tools/fwspi -u 1
          Boardset:     0 B-1000                         (v1.0)
          Baseboard:    0 B-1000                         (v1.0)
          Firmware: v5.3 (for 0-1)
          PLEASE UPGRADE FIRMWARE TO 6.30 - to proceed, execute fwspi -P -U
          And that :
          unipi@L203-sn121:~$ sudo /opt/unipi/tools/fwspi -u 1 -P
          Cannot open file /opt/unipi/firmware/B-1000-1.bin
            Hello @paolo,
            just do as the command says, you need to add "-U" to upgrade the firmware from v5.x to v6.x.
            P 1 Reply Last reply Reply Quote 1
              Thank you @cleve
              It works with
              unipi@L203-sn121:~$ sudo /opt/unipi/tools/fwspi -u 1 -P -U
              unipi@L203-sn121:~$ sudo /opt/unipi/tools/fwspi -u 2 -P -U
              unipi@L203-sn121:~$ sudo /opt/unipi/tools/fwspi -u 3 -P -U
