    node red istance to be interfaced to Mervis PLC
    Node-RED
    2417
      arolli last edited by
      Hi all,
      I have a stable Mervis environment with Neuron + several extension. I want use a dedicated node red instance on dedicated HW and finding a way to interface it with Mevis. There is way to read and write Mervis Global Varialbles trough Modus TCP/IP?
      Antonio
        Martin Kudláček @arolli last edited by
        Hi @arolli,
        this is theoretically possible, but the easiest solution is to spin a ModbusTCP server in the Mervis and communicate over this protocol. The BACnet/IP would be easier to interface from the Node-RED, but we don't have any Node-RED nodes tested for this. The node-red-contrib-modbus works OK.
          @Martin-Kudláček said in node red istance to be interfaced to Mervis PLC:
          Thanks Martin,
          how to spin Modbus TCP on Mervis?
          Antonio
            Hello @arolli,
            please follow this tutorial: https://kb.unipi.technology/en:sw:01-mervis:setting-modbus-server-hidden#setting_modbustcp_server_slave
              Thanks Martin
              now it's clear and working.
              Antonio
              • U
                udokra last edited by udokra
                Hallo
                Ich habe bei mir ein unipi 1.1 bekomme auch Information von mervis zurück ,jetzt meine Frage ,wieviel Modbus Knoten kann ich in node red einbringen.
                Ich habe 3 Stück, bei den die Verbindung unterbricht
                Was mache ich falsch
                Dankeschön für eure Antwort
                Udo
                U 1 Reply Last reply Reply Quote 0
                • U
                  udokra @udokra last edited by
                  This post is deleted!
