    Could not find PLC via UDP
    4208
    • U
      ufa last edited by tomas_hora
      Hi
      when i attach the unipi 1.1 i bougt last week
      it did noch found a plc via UDB Broadcast
      i tried it manually , without a device identifer because i have no!=, but when i try do deploy a solution then it did not work
      mervis result :is controler is only partly attached
        tomas_hora administrators @ufa last edited by
        Hello @ufa,
        did you insert the microSD card in RPi with the Mervis image according to the step by step guide? Do the LEDs on the LAN connector blink when you have the cable connected to UniPi and to your router?
        U 2 Replies Last reply Reply Quote 0
        • U
          ufa @tomas_hora last edited by
          @tomas_hora said in Could not find PLC via UDP:
          yes i have done this
          i can connect to unipi via ssh without a problem
          but no chance to connect via plc attach mervis
          • U
            if i coonect manualy i am ask for a divice identifer
            is it important ?
            • I
              Iogo last edited by
              At first it needs to be connected to dhcp. Then UDP works. After you have first made successful contact you can update the ip-address and disable dhcp.
              You need to update the controller via: PLC -> PLC operation -> PLC setup -> Upload Configuration
              Correct me if I am wrong :)
              U 1 Reply Last reply Reply Quote 0
              • U
                ufa @Iogo last edited by
                @Iogo
                yes i know but upload failed
                I think unipi board is dead raspberry is woring
                is the there a chance to test it
                http://192.168.0.98:8088/ the evok control bord shows no relays ?
                • I
                  Iogo last edited by
                  I was in the assumption that the unipi = raspberry with extra modules.
                  • U
                    @Iogo
                    i bougt a unipi 1 with a rasp 3 from you
                    mervis coult noch attach plc properly
                      @ufa If you can ssh to the RPi with Mervis IMG on it, issue 'systemctl status mervisrt' and you will see if it runs OK.
