    Set ControllerType input of B31_REVERSE_ON_OFF_CONTROL_SEQUENCE
    1
    858
      arolli last edited by
      Re: How to set CONTROLLERTYPE to heating
      Hi Martin
      I'm againg on the same topic after some months.
      I'm not able to set (I'm using an ST program) the value of input "ControlType" of block B31_REVERSE_ON_OFF_CONTROL_SEQUENCE.
      I search into help but there is no example of ST program that explain how to set the input.
      I Tried
      PROGRAM B31_TEST
      VAR IN1, IN2:REAL;
      O1: BOOL;
      FB: LIB.CORE.V1_0.B31_REVERSE_ON_OFF_CONTROL_SEQUENCE;
      END_VAR
      FB(X:=IN1,CONTROLLERTYPE:=COOLING, W:= IN2);
      O1:= FB.OUT;
      END_PROGRAM
      but
      i get the error "can not find the object 'COOLING' in the current context"
      Antonio
