    Merge REAL to ARRAY
      tgurecky last edited by
      I have a question if you can merge several real type variables into one array using a function block?
        Martin Kudláček @tgurecky last edited by
        Hello @tgurecky,
        the "Multi In Real" should do what you are looking for.
          tgurecky @Martin Kudláček last edited by
          Hello @martin-kudláček ,
          thanks for the tip, but in my case I can't use it.
          I need to write to XValue (Array 10) and MultiInReal has (Array 16) see screen.
          Probably the only solution will be via ST.
            Hello @tgurecky,
            in this case, the only way is the ST. Do you need some help with that?
