    Compatibility between Nymea and Mervis
    2947
      msoenen last edited by
      Hello
      is it possible to install the Nyméa interface on a unipi L203 with system mervis?
        Martin Kudláček @msoenen last edited by
        Hello @msoenen,
        we don't have any experience with Nymea, but from their website the support for Raspberry Pi is ready via their own OS image. How would you like to use Nymea together with our PLCs?
          I saw on your site, the following project `` `
          (https://www.unipi.technology/reference/hot-tub-automation-using-the-unipi-1-1-229)
          or unipi is in association with Nyméa to carry out a remote management with smartphone with alarm notification, which is not possible, or difficult via Mervis.
          now, if you know another platform compatible with Mervis for with the same possibilities, am I open to any proposals?
            Hello @msoenen,
            this was a project of our customer. You can try contacting him via this thread: https://forum.unipi.technology/topic/824/hot-tub-controller-with-unipi-1-1
              Hello, thanks for the answer
              I was seeing the topic, my question is this, is it possible to connect via SSL to change the settings of the Pi3 that is in the Neuron to change the configuration of the wifi, and install an additional program (ex Nymea or other)
              thank you in advance
                Hello @msoenen,
                the Raspberry Pi in the Neuron can be can be customized as any other Raspberry Pi. If you are using Raspbian, you need to enable SSH first (https://www.raspberrypi.org/documentation/remote-access/ssh/) and then you can do whatever you need to do.
                  Ok, but on the SD card with Mervis bought with the Neuron, is raspbian installed, or should raspbian be installed, and how?
                  Thank you
                    Hello @msoenen,
                    any SD card you bought from us is empty - we don't preinstall any operating system.
                    I would recommend flashing a UniPian to the SD card. The UniPian is Raspbian with preinstalled packages that allow communication with IO boards.
                    The UniPian image can be downloaded here: https://kb.unipi.technology/files:software:os-images:00-start
                    And here is a tutorial how to flash the MervisOS image to the SD card and you can use parts of it for flashing the UniPian image as well: https://kb.unipi.technology/en:sw:01-mervis:running-on-neuron-hidden
