Navigation
    HMI update issue
    1452
      msoenen last edited by
      I have a problem with the update of the HMI screens of my project
      10 days ago, I did a test in a first new solution with an HMI project, and it worked well and I had access to the screen via Android
      I just made a new solution with a new HMI project, but when I want to access the HMI screen via Android, or Chrome, I still have the old HMI page
      how refresh the pages of the HMI screens?
      Thank you in advance
        Martin Kudláček administrators @msoenen last edited by
        Hi @msoenen,
        there could be two major reasons. Make sure, that you have selected the HMI template in the PLC properties. Also when deploying the solution, there is a option to include the web files into the deployment, which is by default unchecked. Try reading this article how each of the mentioned options is done: https://kb.unipi.technology/en:sw:01-mervis:creating-simple-hmi-hidden
          [Listen to the translation] Hello, and a happy new year 2019
          It works, thanks for your help
          Another small question about HMI
          for the gadget 'BUTTON', it is impossible to assign a variable
          how do we make a push-button?
            tomas_hora administrators @msoenen last edited by
            @msoenen use Digital Setter or Digital Setter ComboBox
              The problem with the digital setter is that they work in
              push > relay goes on
              release > relay stays on
              push > relay goes off
              release > relay stays off
              while I would simply like an on-off function
                @msoenen There is no function like this yet. The only possibilities are the Digital Setter or Digital Setter ComboBox
                  msoenen @tomas_hora last edited by
                  @tomas_hora
                  hello, I found a solution to turn a digital setter into push-Button
                  I put a flip-flop that reset after 2 seconds the variable on which points the digital setter HMI
                  https://www.dropbox.com/s/dvf4toi76z35kxw/Capture d'écran 2019-01-10 09.56.36.png?dl=0
                  1 Reply Last reply Reply Quote 2
