    Mervis 74371 - Analog Out Inverted?
    2 Posts 2 Posters 1.4k Views
      CKB
      I just updated my UniPi1.1 devices to the new 1.7OS using Mervis 74371 and recognized that the Analog Out values have been inverted:
      formerly int=10.000 meant 0V and int=0 meant 10V
      now int=10.000 means 10V and int=0 means 0V
      Did this happen by accident?
      BTW - is there a way to smoothen the AO changerate so I can get rid of the steps? (I see it in my light when dimming up and down)
      see for instance here:
      CKB
      T 1 Reply Last reply
        tomas_hora administrators @CKB
        @ckb the inverse behavior of AO was a bug and is now fixed. Since 0 is a default value, most users do not want a default 10V after startup of the application.
        You would have to smoothen it in the SW - create your own function block which will add/deduct automatically every a part of the difference |current_voltage-target_voltage| every cycle(or every 0.1s). But honestly, this most probably will also cause visible steps in the dimming process.
