    S103-G use GSM/GPRS module to connect to internet
    29 Posts 6 Posters 22.8k Views 2 Watching
    • roberts_landoR
      roberts_lando @unix
      @unix you welcome! :)
      • Vesa KauppinenV
        Vesa Kauppinen @roberts_lando
        @roberts_lando said in S103-G use GSM/GPRS module to connect to internet:
        Hi!
        Great tutorial!
        I use Raspbian Stretch Lite and I can not get the S103-G to work with these instructions. The command cu -l / dev / ttyAMA0 crashes when I try to AT command. Ifconfig does not give ppp0.
        What have I missed?
        Vesa
        U 1 Reply Last reply
        • U
          unix @Vesa Kauppinen
          @Vesa-Kauppinen
          Hi
          have you disable the BT on Pi3
          /boot/config.txt addline
          dtoverlay=pi3-disable-bt
          and on /boot/cmdline.txt remove
          serial console than its looks like
          dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=e13fdf55-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
          Regards
          Vesa KauppinenV 1 Reply Last reply
          • Vesa KauppinenV
            Vesa Kauppinen @unix
            @unix
            Thank you for answer!
            BT disabled and cmdline.txt edited...
            No success
            @tomas_hora any ideas?
            Vesa
            • roberts_landoR
              roberts_lando
              I always had compatibility problems when using Raspbian Stretch, try to use last Raspbian Jessie img and it should work
              • Vesa KauppinenV
                @roberts_lando
                Now i have tried with Rasbian Jessie Lite.....no success :disappointed:
                Do you use Jessie Lite or full?
                Thanks,
                Vesa
                roberts_landoR 1 Reply Last reply
                • roberts_landoR
                  roberts_lando @Vesa Kauppinen
                  @Vesa-Kauppinen I think you have missed one or more step of the turorial. I suggest you to retry the tutorial and check if an instruction fails. Do you have switch on the GPRS module?
                    mattia98 @roberts_lando
                    @roberts_lando Hi, I've done all the steps to configure the internet connection but when I type "ifconfig" it doesn't show me the ppp0 interface. Could you please help me?
                    when I type the command "cat /var/log/syslog" It show me this messages:
                    Sep 4 13:41:52 raspberrypi pppd[1698]: pppd 2.4.7 started by root, uid 0
                    Sep 4 13:41:52 raspberrypi chat[1702]: abort on (BUSY)
                    Sep 4 13:41:52 raspberrypi chat[1702]: abort on (VOICE)
                    Sep 4 13:41:52 raspberrypi chat[1702]: abort on (NO CARRIER)
                    Sep 4 13:41:52 raspberrypi chat[1702]: abort on (NO DIALTONE)
                    Sep 4 13:41:52 raspberrypi chat[1702]: abort on (NO DIAL TONE)
                    Sep 4 13:41:52 raspberrypi chat[1702]: abort on (NO ANSWER)
                    Sep 4 13:41:52 raspberrypi chat[1702]: abort on (DELAYED)
                    Sep 4 13:41:52 raspberrypi chat[1702]: abort on (ERROR)
                    Sep 4 13:41:52 raspberrypi chat[1702]: abort on (+CGATT: 0)
                    Sep 4 13:41:52 raspberrypi chat[1702]: send (AT^M)
                    Sep 4 13:41:52 raspberrypi chat[1702]: timeout set to 12 seconds
                    Sep 4 13:41:52 raspberrypi chat[1702]: expect (OK)
                    Sep 4 13:42:04 raspberrypi chat[1702]: alarm
                    Sep 4 13:42:04 raspberrypi chat[1702]: Failed
                    Sep 4 13:42:04 raspberrypi pppd[1698]: Connect script failed
                    Sep 4 13:42:10 raspberrypi OWFS[477]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
                    Sep 4 13:42:30 raspberrypi OWFS[477]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
                      tomas_hora administrators
                      The issue was by the incorrect comm speed with the modem. I modified the guide provided by @roberts_lando to use the proper baudrate of 9600 instead of 115200.
