    Unable to use apt-get on Mervis OS img
    • roberts_lando
      I have an Unipi Neuron S103-G, img UniPi-Mervis-OS-2017-08-28_v1.3 (lastest). After SSH into Neuron using root:unipi I'm not able to download any package. I have run the command mount / -o remount,rw but when I run apt-get update It is stucked to this line for some minutes:
      [Connecting to xvdevel.faster.cz (81.19.0.27)]
      Than:
      Cannot initiate the connection to xvdevel.faster.cz:3128 (2a02:e98::27). - connect (101: Network is unreachable) [IP: 2a02:e98::27 3128]
        @roberts_lando We forgot one settings for ou internal tests.. Just delete the /etc/apt/apt.conf.d/60proxy file
        • roberts_lando
          @tomas_hora @administrators Is there a way to install Mervis Runtime in an existing img instead of using the image you provide? This would be nice as feature as you could also add the possibility to update your runtime instead of install an entire new image every time an update is released
            @roberts_lando We do not plan to do that right now
