    Remote connection problem [Mervis]
    UniPi 1 - First Generation
      TriathletC last edited by tomas_hora
      Good morning I found the abnormalities of my PI1.
      I created the program and the HMI..HO graphics downloaded all in the PLC and it seems to work properly if I connect via lan cable from my PC to the IP.
      The problem is whether I connect LAN over a HUB switch or home ADSL router.
      In theory and in practice being connected to wi-fi I should see it right? but it is not so ... I can not even ping it.
      I tried to do a second test .. I connected the PI to a Wi-Fi Access Point I use for work..and once I connect I can not reach it..what ever need to give some particular setup to the PI..this Mervis ..
        tomas_hora administrators @TriathletC last edited by
        @TriathletC So everything solved?
          TriathletC @tomas_hora last edited by
          @tomas_hora
          Fixed Thomsas .. I connected UNIPi to the network and I redesign the detect .. once found through the Mervis I have downloaded the settings .. it works ..
