Relays not shown on the Evok API
Hey Community,
i just will not get started with your UniPi v1.1..
i have installed the evok software as shown on github
(https://github.com/UniPiTechnology/evok). If i now type in the ip of my raspi, into my
browser, i only see the inputs of the board. If i click the outputs,
i just see the header "Outputs", but not one relay is listed here (Screenshot).
On the internet i don´t really get some information, what the problem could
be. Do you have any idea how it could work?
Is there a possibility, to check if the board is working correctly?I am using a Raspberry Pi3B with the OS: 2017-03-02-raspbian-jessie
The UniPi´s rev is 1.1Further i have some screenshots for you and a logfile
pi@raspberrypi:~ $ sudo /opt/evok/evok.py Listening on port: 80 Error in config section EPROM_1 - 'I2C read failed' Error in config section MCP_1 - 'I2C write failed' Error in config section RELAY_1 - Invalid device circuit number 1 Error in config section RELAY_2 - Invalid device circuit number 1 Error in config section RELAY_3 - Invalid device circuit number 1 Error in config section RELAY_4 - Invalid device circuit number 1 Error in config section RELAY_5 - Invalid device circuit number 1 Error in config section RELAY_6 - Invalid device circuit number 1 Error in config section RELAY_7 - Invalid device circuit number 1 Error in config section RELAY_8 - Invalid device circuit number 1 Error in config section AI_1 - Invalid device circuit number 1 Error in config section AI_2 - Invalid device circuit number 1 Entering measure loop New WebSocket client connected [I 170411 10:11:16 web:1971] 304 GET /rest/all/ (127.0.0.1) 10.61ms Process OwBusDriver-1: Traceback (most recent call last): File "/usr/lib/python2.7/multiprocessing/process.py", line 258, in _bootstrap self.run() File "/opt/evok/owclient.py", line 341, in run ow.init(self.bus) File "/usr/lib/python2.7/dist-packages/ow/__init__.py", line 224, in init raise exNoController exNoController
Best regards
Benedikt Stahl
Hello @s0fralk,
it looks like the I2C bus is not enabled. Which is wierd because it is enabled during the installation. Could you please check it?
That was my first thought too, after reading this log. So I enabled it manually just to go safe, but it didn´t changed anything. Here is a list of the i2c module:
pi@raspberrypi:~ $ lsmod | grep i2c_ i2c_bcm2708 4834 0 i2c_dev 5859 6
pi@raspberrypi:~ $ sudo i2cdetect -y 1 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- ```
No more idea? Is there a possibility to check the relays/board itself? Normally it should work after installing evok as shown on github, right?
Well... i decided to buy another i2c device and test it. the result: this works without any problems, so i think my board is faulty..
And the /boot/config was the same @s0fralk? Because every board and cable is tested before we ship it. Was it working for at least a while? Could you please provide the serial number of your UniPi?
