"True" Domoticz support for UniPi
Re: Domoticz
The Domoticz beta version (3.6584) supports python based plugin modules. By that it is possible to add native support for new HW modules without the need for C programming. I have developed a plugin for UniPi. It supports relay control and also 1-wire temp sensors. The relays are controlled by 8 Domoticz switches (toggle on/off). They are automatically added to Domoticz once a UniPi HW module is added on the HW setup tab. 1-wire temp sensors will be automatically deteced and added as Domoticz temp as soon as they are connected.
With this plugin module you do not need to do the tedious mapping between virtual devices and lua scripts any more. Just add a UniPi module and off you go!
Up until now there is no officially promoted way to share python plugins for Domiticz. Are you interested in my plugin module, send me personal message and I will share it with you.
Thanks a lot @ubee !
That is great. Do you plan to release the plugin for public, eg github? I can create a category for Domoticz on our forums...
I can release it in public. I guess the most convenient way is to do it with git. However, it is just one single file, so it is not that complex. The needed documentation is in the top of the file.
Hello. How can I send a private message? I do not see this option.
I started a chat with you Ubee, but you did not answer.
@informatyk https://forum.unipi.technology/user/informatyk The first item in the menu if you click on the user menu blue circle. But the user will only see the message after loggin back in,
Hello
I am interested in testing your plugin Domoticz and Unipi
I have sent a request in chat
Sincerely
Anders
Ok thanks check there
This post is deleted!
