    Domoticz
    General Discussion
    1
    8
    4154
    • B
      BlackSoll last edited by
      Really interesting light weight application.
      https://www.domoticz.com/
      Can someone help me make a plugin for unipi ? Tried but always dead end.Can't make unipi to work with it
      Sould i try with this or i might fry the unipi ?
      @251txih6:
      Consequently, the GPIO pins you want to use must be "exported" and configured (using the "gpio" tool included in wiringPi) before starting domoticz (that should normally be done in a script upon boot, before domoticz starts)
      http://www.domoticz.com/forum/viewtopic ... 19&p=15225
      • B
        @251txih6:
          Guest last edited by
          Looks interresting but you would need much more than the GPIOs to make UniPi to work with domoticz.
          However UniPi is fully supported in fhem.de ( see our shop for iso) and we are also planning supoort for pimatic which might also suit you.
            By the way, maybe it would be easier to implement the plugin using the websocket API of Evok… What do you think?
            • B
              I'm working with a lua script, which is using evok, to make thinks work. The first part with the relay automation i think is finished with a big help from another member.
              The analong inputs - outputs, the one wire sensors e.t.c…...not working....Looking for solution ....
              Maybe i can sent you the script to have a look when you have time. I can't attach file here so you can pm me your email to sent it to you.
              Lua is integrated in Domoticz and with a script there is no need for plugin.
              https://www.domoticz.com/wiki/Domoticz_ ... ua_scripts
              Thanks !
              • B
                Hi Tomas !
                I'm wondering if you take a look at the script and if you have any solution for the 1wire temp sencors.
                • B
                  Still looking ways to make thinkgs work…....
                  Domoticz have built in support of node-red and node.js.
                  https://www.domoticz.com/wiki/MQTT
                  https://www.domoticz.com/wiki/Flows
                  Is this an alternative way, with creating little programs (flows), to interface UniPi with domoticz ?
                  I'm not a programmer and don't really know much...Just basic knowledge of how thinks work, so forgive me if i ask to much...
                    I would really like to help you out with the domoticz implementation but I still do not have enough time for that… But domoticz is a really interresting project which I think should have a full support for UniPi.
