Mervis is slow
I have installed the mervis runtine on the Raspberri Pi. I used version 2.05 of the IDE and the runtime. This Raspberri is mounted on an UNIPI board and 2 extra relay-boards connected via the I2C bus.
The plc is running at 16.6 ms. the I2C enpoint is updated with 565 ms. It is almost the same as the one-wire temperature meter, 661 ms.
I tried different I2C speeds, There was no change in reaction time.
Is this End point speed normal? or must i use another runtime version?I included pictures of the runtime status and the configuration.
All tips are welcome :)
Hello, how many I2C and 1Wire devices is in your application? The 1Wire is implemented using also the I2C bus so it is shared for both 1Wire and relays... However I tried 1 temp sensor and 1 emo-r8 with max 24ms at I2C and 46 at 1Wire.
I have one 1-wire temp -meter and 2 external I2C relay-cards (emorelay-boven and emorelay-beneden).
These relay-cards and the unipi card are supplied by separate adapters, so the grounds are not coupled.
Can this have influence on the speed?if in the program 2 relays are switched at the same time (each relay on a separate relay card), i can see that they are switched one after the other. at least 0.5 sec after each other.
I would be nice if all relays could be switched in 100ms.
I use the older mervis runtime (version 2.5) on a Rasberry Pi B+, is the last runtime faster or is there no difference is speeds.
Kind regards,
Frans.
