    Evok brings 404 Error
    • K
      knebb last edited by
      I am still on Buster (Update failed), my Evok Version ist 2.4.34. Usually I do not need Evok but I wanted to test something manually without writing code.
      So I started with systemctl:
      systemctl start evok and after this I can see port 808 is LISTENing (was not before):
      root@neuronm103:/usr/src# netstat -anp| grep pyth
      tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      20899/python
      But when I use my browser I am getting a "404: Not Found" error. I tried to look into the logfiles but there is nothing related.
      In /var/logthe following files are empty:
      evok.log
      nginx/*log
      Anyone having an idea how to get it up and running?
      Thanks!
      /KNEBB
        cleve administrators @knebb last edited by
        Hello @knebb ,
        unfortunately we do no longer support Evok v2. However, I can assist you with Evok v3, how did the update fail, what did you do?
        • K
          knebb @cleve last edited by
          @cleve
          Thanks for replying.
          I will try the update again and create a new topic in case it fails.
          /KNEBB
