Evok brings 404 Error
I am still on Buster (Update failed), my Evok Version ist 2.4.34. Usually I do not need Evok but I wanted to test something manually without writing code.
So I started with systemctl:
systemctl start evokand after this I can see port 808 is LISTENing (was not before):root@neuronm103:/usr/src# netstat -anp| grep pyth tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN 20899/pythonBut when I use my browser I am getting a "404: Not Found" error. I tried to look into the logfiles but there is nothing related.
In/var/logthe following files are empty:
evok.log
nginx/*logAnyone having an idea how to get it up and running?
/KNEBB
Hello @knebb ,
unfortunately we do no longer support Evok v2. However, I can assist you with Evok v3, how did the update fail, what did you do? -
@cleve
Thanks for replying.I will try the update again and create a new topic in case it fails.
/KNEBB
