https redirect
I'm using IDEv2.5.0 with an Axon M505. I want to disable http access to the HMI and redirect http to https, so I've set the Networking configuration as shown. Neither seems to work. I'm still able to access the PLC over http despite uploading the configuration and deploying the solution with a cold restart. Is there something else I need to do or do these options just not work?
@Matt
I have tested this and you are probably right, those options seem to be not implemented. However, I was able to disable HTTP on a testing branch of Mervis. This version will be released later this year. As a solution for now, you can try using HTTPS only mode in your browser.Best regards,
Kryštof Černý
