Modbus TCP (unipitcp) not working on Neuron with Raspberry OS
The unipi_tcp_server reports the following error:
sudo /opt/unipi/tools/unipi_tcp_server -p 502 -l 127.0.0.1 --verbose --check-firmware ARMINIT: Cannot open device /dev/unipispi ARMINIT: Cannot open device /dev/unipispi ARMINIT: Cannot open device /dev/unipispi UniPi TCP Modbus Server: Listening Connection Established RET:3 poll timeout = -1[ms] Starting primary loopWhen trying to communicate with the server, errors are reported: Error reading (using EasyModbus Java library).
This is the environment:
I installed raspios_lite_arm64-2020-08-24 on Neuron S103 (RPI4).
The image is available here: https://downloads.raspberrypi.org/raspios_lite_arm64/images/raspios_lite_arm64-2020-08-24/2020-08-20-raspios-buster-arm64-lite.zipNext I added the Unipi repository the recommended way:
curl https://repo.unipi.technology/debian/README.apt | bashSubsequently I installed the following modules:
sudo apt install -y unipi-kernel-modules unipi-firmware unipi-firmware-tools unipi-modbus-toolsFinally I run
sudo systemctl stop unipitcp sudo /opt/unipi/tools/unipi_tcp_server -p 502 -l 127.0.0.1 --verbose --check-firmware -
@noelvaes Did you reboot after the kernel modules were installed?
