    Modbus TCP (unipitcp) not working on Neuron with Raspberry OS
    2 Posts 2 Posters 912 Views 1 Watching
    • N
      noelvaes
      The unipi_tcp_server reports the following error:
      sudo /opt/unipi/tools/unipi_tcp_server -p 502 -l 127.0.0.1 --verbose --check-firmware
      ARMINIT: Cannot open device /dev/unipispi
      UniPi TCP Modbus Server: Listening Connection Established RET:3
      poll timeout = -1[ms]
      Starting primary loop
      When trying to communicate with the server, errors are reported: Error reading (using EasyModbus Java library).
      This is the environment:
      I installed raspios_lite_arm64-2020-08-24 on Neuron S103 (RPI4).
      The image is available here: https://downloads.raspberrypi.org/raspios_lite_arm64/images/raspios_lite_arm64-2020-08-24/2020-08-20-raspios-buster-arm64-lite.zip
      Next I added the Unipi repository the recommended way:
      curl https://repo.unipi.technology/debian/README.apt | bash
      Subsequently I installed the following modules:
      sudo apt install -y unipi-kernel-modules unipi-firmware unipi-firmware-tools unipi-modbus-tools
      Finally I run
      sudo systemctl stop unipitcp
        tomas_hora administrators @noelvaes
        @noelvaes Did you reboot after the kernel modules were installed?
