Unipi 1.1 Real Time Clock (RTC)
Hello everyone,
I wonder how the real time clock works with the Unipi 1.1?
Every time the raspberry has been off for 10 minutes, the clock is 10 minutes behind.
Can anyone help me?
Hello @wolge, what OS image do you use? In images provided by us, the RTC is enabled in the config.txt. On stock Raspbian, this is disabled.
Hello @Martin-Kudláček , I use Debian Buster. I can change the config.txt by myself.
-Can you help me what to change?
-Or is it possible that you send my the config.txt with the right settings?
@Martin-Kudláček I installed the "Unipi 1.1 Node-RED OS" image. But after I put the SD card in the Raspberry Pi the image will not starting right. I get the following screen:
Am I doing something wrong?
I installed the image on the SD card with a program named "ApplePiBaker" and now it works!
