    Function block - variable number of inputs
    function block
      tmmke last edited by
      I would like to make a function block with a variable number of inputs.
      Like with the standard AND operation for example.
      Does anyone know how I can achieve this?
      It doesn't matter if it has to be in ST of in FBD.
      Kind regards,
      Tom
        This is not a standard feature of ST or FBD but there is a small hack to achieve this. See the example below. It only works if the input variable is named "in" (the same works for output variable named "out") and the type is array.
        FUNCTION InDemo : LINT
        VAR
        i : INT;
        END_VAR
        VAR_INPUT
            In : ARRAY[0..63] OF BOOL;
        END_VAR
        (*function block's body*)
        result := 0;
        FOR i := 0 TO 63 DO
               // nejaky kod
             IF In[i] THEN result := result + 1; END_IF;
        END_FOR;
        InDemo := result;
        END_FUNCTION
