    Unipi Opentherm To Modbus MM-OT101 - Communication Problems
    Scheduled Pinned Locked Moved General Discussion
    2 Posts 2 Posters 1.1k Views
    • F
      francoinf
      Good evening,
      I tried to connect the gateway referred to in the object to a BAXI boiler, and I noticed that some information I can read while others do not.
      For example, I can read the room temperature (address 24), all registers from 2000 to 2010, but many other registers, such as 27 (outside temperature), I cannot read them.
      An error appears in the thermostat (error 88E, which means communication problem). The communication problem encountered is however partial, because as mentioned some registers there
      I read correctly, others do not (where I do not read the data correctly, I read the value 0).
      Can anyone show me how I can solve the problem?
      Thank you
        tomas_hora administrators
        Can you check the statistics registers 2000+ / 2100+?
