Unipi Opentherm To Modbus MM-OT101 - Communication Problems
Good evening,
I tried to connect the gateway referred to in the object to a BAXI boiler, and I noticed that some information I can read while others do not.
For example, I can read the room temperature (address 24), all registers from 2000 to 2010, but many other registers, such as 27 (outside temperature), I cannot read them.
An error appears in the thermostat (error 88E, which means communication problem). The communication problem encountered is however partial, because as mentioned some registers there
I read correctly, others do not (where I do not read the data correctly, I read the value 0).
Can anyone show me how I can solve the problem?
Thank you -
Can you check the statistics registers 2000+ / 2100+?
