Wifi connection
I have configured my unipi 1.1 in wifi on my AP but I cannot access it via mervis or on the web interface.
What did I miss in my configuration?
Cordially.
Hello @mmcreativ,
have you uploaded the configuration into to PLC afterwards?The only way to debug this is to SSH into PLC and check the interfaces:
sudo ip a
I've upload the configuration.
The Unipi is connected to wireless network but when i disconnect eth, i cannot access to the Unipi.
Hi @mmcreativ,
the issue might arise, if you try accessing the IP 192.168.8.91 from another subnet. The WiFi interface doesn't have default gateway set, therefor it doesn't know how to reach different subnet. Could this be the issue?Best regards,
