    HMI Interface ?
    Scheduled Pinned Locked Moved Other Peripherals
    2 Posts 2 Posters 1.1k Views
    • W
      wavoigt
      Hi, i need to use a HMI with Neuron xxx, how to interface it?
      T 1 Reply Last reply
        tomas_hora administrators @wavoigt
        @wavoigt We have tested HMI terminals from weintek like this one https://www.unipi.technology/weintek-mt8051ip-p198?categoryId=29 via Modbus RTU (RS485). Works well but the SW setup is a bit complicated.
        Mervis has recently gained BACnet server support so you can connect higher verions of Weintek displays which support BACnet with Neuron or Axon via BACnet/IP
        Alternatively Mervis has a web based HMI so you can also use this with any web browser while on the same IP network.
