    Unipi I2C Relays Problem
    Unipi 1 - HW Q&A
    • P
      pablofsmelo last edited by
      Hello
      I am trying to drive unipi relays through a ladder code developed under the openplc project, but nothing happens.
      I tried to make all the necessary settings to run i2c, but when I run the command "i2cdetect -y 1" I would expect to receive the address of CI MCP23008 (0x20) and other i2c devices. I tried to use all the power combinations for RPI and the expansion board, but nothing works.
      Can someone help me ?
      I'm using unipi1.1 from Raspbian Stretch 9.9
        Make sure the I2C bus is enabled or enable it using raspi-config tool. You should see all the I2C devices as listed in the documentation - eg. 0x18 for the 1Wire interface
        • P
          Hi Thomas,
          I believe this is set up correctly. After this configuration, I rebooted the system but nothing happens with i2c.
          • P
            pablofsmelo @tomas_hora last edited by
            @tomas_hora
            I performed all the settings as per this link (https://www.raspberrypi-spy.co.uk/2014/11/enabling-the-i2c-interface-on-the-raspberry-pi/) and it didn't work out.
            I'm suspecting that the problem is with unipi1.1 hardware, but I would like more testing alternatives before concluding this.
            Can anybody help me ?
              @pablofsmelo did you figured it out?
