    Disable unipi modbus tcp service
    Axon series
    • roberts_lando
      Hi, I have disable evok and mervis from the axon web interface but the unipi tcp service is still up.
       session-29.scope        loaded active running   Session 29 of user unipi
      unipicheck.service        loaded active exited    Check Unipi/Neuron/Axon version
      unipihostname.service        loaded active exited    Set default hostname on Neuron and Axon
      unipitcp.service        loaded active running   Unipi Neuron/Axon Modbus/Tcp Server
      user-1000.slice        loaded active active    User Slice of unipi
      unipispi.target        loaded active active    Neuron/Axon Target
      I have disabled it using sudo systemctl disable unipitcp.service, I think there should be a way to disable it using the web interface or disable it when disabling evok/mervis
      I also would like to know what is unipispi.target service used for and also unipicheck.service and If I can disable them If I'm not using mervis
        @roberts_lando The unipispi and unipicheck are common launchers of Neuron/Axons jobs (hostname generation, certain steps to setup some certain models, optional auto firmware upgrade, ... and running the unipitcp service). Check the /etc/systemd/system/unipispi.target.wants/
        The unipitcp is a common interface and listens only on the local loopback so its not a security issue. If you do not use it, it it actually does not do anything
        • roberts_lando
          roberts_lando @tomas_hora last edited by
          @tomas_hora it's not a security issue but as I'm using another plc runtime with a local modbus tcp master running on port 502 unipitcp service was blocking it. I have disabled it and modbus has started working correctly
