Raspberry pi 4
Short question, will Unipi upgrade to the new raspberry pi 4?
Short answer: yes. But it will take time, since we need to change the enclosure as well, due to the changed position of the ethernet and USB.
@martin-kudláček
If you are handy, and make new hole's could you also replace your Pi your self?
@havor wel... you could. in case of Neuron, you would be dealing with a warranty voided unit and possible heat issues caused by the new design of RPi4.
