    Node-Red and Unipi extensions.
    Node-RED
    3082
      Schteven last edited by
      Hi
      I'm working with Unipi Neuron for a few months now on a very basic level.
      As I am now switching from Mervis to Node-Red, it's all very new to me.
      My Unipi Neuron L203 has two xS11 extensions connected to it which are communicating perfectly with the Mervis IDE. With Node-Red now, I have no idea how to get them linked to the Neuron. I went through some tutorials how to set up the modbus et cetera but everything about this is top of the notch rocket science to me.
      Does anyone has a step by step tutorial how to set this up?
      Any help is more than welcome!
      Reason of the switch to Node-Red is because I need MQTT support to use my Android app with.
      Thanks.
        Martin Kudláček @Schteven last edited by
        Hi @Schteven,
        since the Node-RED is using Evok API, the best way is to configure the Evok to read the extensions as well. This is done in the /etc/evok.conf. There are prepared and commented blocks, you can see the default version here: https://github.com/UniPiTechnology/evok/blob/master/debian/etc/armhf/evok.conf#L28
        Once the config is updated, you need to restart the Evok (sudo systemctl restart evok), or the whole PLC. Now you will have the additional datapoints available via the API.
        You can find out about the configuration of the extensions here: https://kb.unipi.technology/en:hw:04-extensions:communication-and-addressing-of-module
          MirekV @Martin Kudláček last edited by
          @Martin-Kudláček
          Ahoj,
          tak mám podobný problém s připojením extensionu XS11. Komunikaci jsem již nějak zvládl, ale nedaří se mi dostat do nastavení EVOKu, abych měl přístup k jednotlivým vstupům..
          Bylo by možné nějak konkretizovat toto nastavení..
          Díky
            Martin Kudláček @MirekV last edited by
            Ahoj @MirekV,
            v jakém kroku jsi se zaseknul? Jsou vstupy a výstupy vidět v Unipi Control Panel na portu 80?
            M.
              @Martin-Kudláček ahoj, bohužel jsem řešil jiné věci.. teď se k tomuto problému vracím. bohužel vstupy ani výstupy vidět nejsou.. díky za radu..
              Z 1 Reply Last reply Reply Quote 0
              • Z
                zdenek_rusek @MirekV last edited by
                @MirekV Zdravím, jak vypadá nastavení /etc/evok.conf ? Máte určitě správně nastavenou adresu? (nastavuje se pomocí DIP přepínačů)
                ZR
                  MirekV @zdenek_rusek last edited by
                  @zdenek_rusek mám nastavenou adresu na 3.. první dva přepínače mám zap.. dále vyp, zap a zap.. takže by měla být adresa 3, rychlost 9600, data bits 8, stop bit 1, parity není
                  • Z
                    @MirekV Zdravím, pošlete prosím c&p hw tree části config souboru a fotku DIP přepínačů.
                    ZR
