    Analog Output
    Scheduled Pinned Locked Moved Unipi 1 - HW Q&A
    5 Posts 1 Posters 4.3k Views 1 Watching
      sabrus
      We bought the unipi this month.
      Now we are trying the functionality but we have a problem with Analog Output.
      We tried with pi4j (a java library for gpio) but don't work
      This is the code:
      public static void main(String[] args) throws InterruptedException {
      // initialize wiringPi library
      com.pi4j.wiringpi.Gpio.wiringPiSetup();
      // create soft-pwm pins (min=0 ; max=100)
      SoftPwm.softPwmCreate(1, 0, 100);
      // continuous loop
      while (true) {
      // fade LED to fully ON
      for (int i = 0; i <= 100; i++) {
      SoftPwm.softPwmWrite(1, i);
      Thread.sleep(25);
      // fade LED to fully OFF
      for (int i = 100; i >= 0; i–) {
      Thread.sleep(25);
      the same code with a led on pin work correctly.
      We tried also with wiringpi (gpio pwm command) but on unipi don't work.
      The voltage on AO don't change, we just manage it using the blue trimmer.
      Can you help us?
      Many Thanks.
        sabrus
        This is the code:
        // continuous loop
        while (true) {
        Thread.sleep(25);
        Thread.sleep(25);
        Can you help us?
        Many Thanks.
          Guest
          I am not much familiar with the wiring pi, but according to the softPwmCreate method, you gave it GPIO pin 1 but the AO pin is number 18. Next, do you have correctly wired the AO? Eg. if using the internal 12V power supply: 12V <-> AOV; AI1- <-> AOG ?
          Also we put out the opensource API available on github: https://github.com/UniPiTechnology/evok
          Tomas
            sabrus
            for wiring pi pin the pin number18 is the 1.
            Sorry but i don't understand why you use the AI1.
            We wired the AOV with external power and check the output on AO.
              Guest
              Hello, I have created a simple wiki page. See http://unipi.technology/wiki/Using_Analog_Output
              Let me know if anything is missing or not clear and I will fix it.
              With your input, this post could be even better šŸ’—
