    Push button relay toggle
    mervisneuronswitch
    25 Posts 10 Posters 20.0k Views 1 Watching
    • SorakCzS
      SorakCz
      I am solving same issue. I have ST program. Its reacts only on rising edge. But it is slowly and it not work on every push though I have sleep ratio 5%.
      PROGRAM tlacitko
      	VAR_INPUT
      		tlacitko:BOOL;
      	END_VAR
      	VAR_OUTPUT
      		rele:BOOL;
      	END_VAR
      if (tlacitko=1 AND rele=1)
      THEN
      	rele:=0;
      ELSIF (tlacitko=1 and rele=0) THEN
      	rele:=1;
      ELSE
      END_IF;
      END_PROGRAM
        tomas_hora administrators @SorakCz
        @SorakCz If you want just this functionality then use the Direct Switch. You do not have to program in ST anything and it reacts on every rising edge which mervis does not have to catch (you could try to detect the pushes via counters thought)
          RainerK
          Hi @all,
          I tried to solve the problem by using "Event triggered tasks" maybe @tomas_hora could explain how it could be done this way.
          BR Rainer
          • G
            Giamba
            With the following program, If I "short" push the button, the final out value goes 0 or previous analog value. If I "long" push the button the value increase or decrease.
            So I have short and long push detection and a toggled output.
            This is working pretty well with 50% ratio.
            John-paulJ 2 Replies Last reply
            • G
              Giamba
              Hi again,
              This is my On/Off switch (allways as a fonction block in fdb mode):
              • K
                kolopes
                I have 3 buttons that I want to turn on / off the bulb. (push - lights up, push light off)
                How best to solve.
                thank you for the advice
                  tomas_hora administrators @kolopes
                  @kolopes The asnwer is above. The best is to use the DirectSwitch function (set variables DS_enable and DS_toggle to True). The number of DI(button) must be the same as RO. You can enable this functionality for each pair of DI-Ro/Do. Make sure to set the NV_save variable of the group where this will be configured to True and False afterwards.
                  To be able to set the values, you have to be in debug mode!
                  Alternative approach is to write your own function block that might do much more...
                    sgtgarcia
                    Hi
                    Where can i find the "Direct Switch" function?
                    Are there some more library files i can download somewhere?
                    I am new to mervis and I'am no programmer.
                    The programs above seem complicated.
                    In the logo software there is a block especially for this purpose.
                    It als has an global off function.
                    That is the kind of thing I need.
                      tomas_hora administrators @sgtgarcia
                      @sgtgarcia Direct Switch is a feature of HW of Neuron, it's not a feature of Mervis (but it can be of course programmed for such behaviour). To enable DS, check Mervis variables that start with "DS_" there you will find the DS_enable, DS_toggle and DS_polarity functions.
                        msoenen
                        Hello I would like to activate direct switch, but I can not find how. could you explain?
                          tomas_hora administrators @msoenen
                          @msoenen https://kb.unipi.technology/en:sw:01-mervis:advanced-modes-of-digital-inputs-hidden#direct_switch
                            msoenen
                            Hello, thank you a works, but is it possible to use a 'RO' output with a 'DI' direct switch and another DI or function
                            thank you
                              Right now, you can only link a DiX.Y and DO/ROX.Y - X and Y has to be the same with both DO/RO and DI.
                                msoenen
                                Thank you for the answer, but for my home automation project, I wanted to
                                activate my lamps with pushbuttons ( this OK) and a button to disable all RO at the same time
                                how to do?
                                  @msoenen Then check the "DirectSwitch_force" and its documentation which is part of Lib.UniPi
                                  M 1 Reply Last reply
                                    msoenen @tomas_hora
                                    @tomas_hora Hello, this is the function I'm looking for, but I do not really understand how to do the program in input. would you have an example of a program with this function?
                                    thank you in advance
                                      @msoenen Just the picture in the help of Mervis.. There is actually not much to show.
                                        msoenen
                                        Hello sorry, I am beginner on unipi.
                                        when I do exactly like help, it does not work, it must miss a configuration
                                        Thank you for your help
                                          @msoenen first of all get rid of the warining by removing the first connection, assigning to one variable multiple times in fupla is not allowed
                                          • G
                                            Giamba
