    EVOK TCP-Modbus only responding to loopback address
      alydersen last edited by
      Hi!
      After enabling "allow_register_access" I can access port 502 with telnet locally, but all other connections are not responded to. This used to work, but after an upgrade it seems to binding to the loopback interface only.
      evok.conf:
      [NEURON_1]
      global_id = 1                                                   ; Mandatory, REQUIRED TO BE UNIQUE
      allow_register_access = True
      scan_frequency = 10                                             ; Optional, 10 default, scanning frequency in [Hz]
      scan_enabled = True
      Output from netstat -lptu
      root@L513-sn24:/home/pi# netstat -lptu
      Active Internet connections (only servers)
      Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
      tcp        0      0 0.0.0.0:http            0.0.0.0:*               LISTEN      1001/nginx: master
      tcp        0      0 0.0.0.0:http-alt        0.0.0.0:*               LISTEN      773/python
      tcp        0      0 0.0.0.0:ssh             0.0.0.0:*               LISTEN      997/sshd
      tcp        0      0 localhost:502           0.0.0.0:*               LISTEN      867/unipi_tcp_serve
      tcp6       0      0 [::]:http-alt           [::]:*                  LISTEN      773/python
      tcp6       0      0 [::]:ssh                [::]:*                  LISTEN      997/sshd
      udp        0      0 0.0.0.0:bootpc          0.0.0.0:*                           982/dhcpcd
      udp        0      0 0.0.0.0:48767           0.0.0.0:*                           899/avahi-daemon: r
      udp        0      0 0.0.0.0:mdns            0.0.0.0:*                           899/avahi-daemon: r
      udp6       0      0 [::]:mdns               [::]:*                              899/avahi-daemon: r
      udp6       0      0 [::]:58202              [::]:*                              899/avahi-daemon: r
        BTW: Version is Repository:evok ActiveBranch:[master] PrecedingRelease:v.2.0.7b PrecedingRevision:326(aacb3a9) LatestCommit:Mon Sep 10 11:39:34 CEST 2018
          Martin Kudláček @alydersen last edited by Martin Kudláček
          Hello @alydersen
          yes, this a security feature, because ModbusTCP doesn't have any autentization.
          The unipitcp service is maintained by systemd and the startup parameters are defined in /lib/systemd/system/unipitcp.service. You can modify the ExecStart attribut in this file and add -l 0.0.0.0 to start the service listening on all IP address, not just default loopback.
          The result should look like this:
          [Unit]
          Description=Unipi Neuron/Axon Modbus/Tcp Server
          Before=mervisrt.service
          Before=evok.service
          [Service]
          Type=simple
          Environment="FIRMWARE_UPDATE=1"
          EnvironmentFile=-/etc/default/unipi-modbus-tools
          ExecStartPre=/bin/sh -c 'if [ "${FIRMWARE_UPDATE}" = "1" ]; then /opt/unipi-bin/fwspi --auto; fi'
          ExecStart=/opt/unipi-bin/unipi_tcp_server -p 502 -l 0.0.0.0
          TimeoutStopSec=3
          SyslogLevel=debug
          SyslogIdentifier=unipi
          WorkingDirectory=/opt/unipi-bin
          Restart=always
          [Install]
          WantedBy=unipispi.target
          Then reload the systemd: systemctl daemon-reload
          And reload the unipitcp service: systemctl restart unipitcp
          A 1 Reply Last reply Reply Quote 0
            alydersen @Martin Kudláček last edited by
            @martin-kudláček Thanks! That worked! Maybe you could update your docs?
              @alydersen That will be a tough decision where to put it, but I'll think of something.
              Thanks for the feedback,
                tomas_hora administrators @Martin Kudláček last edited by
                @martin-kudláček Already noted on the prepared knowledge base.
