Wifi communication between 2 unipi neuron
I would like to communicate with each other 2 unipi neuron wifi because I do not have the opportunity to pull a connecting cable between my two boxes. Is it possible to perform this communication so that my first unipi sends a command order to the second?
Thank you in advance. -
@ikiiwii Will they be on same network? What software do you want to use - Mervis or anything other?
@tomas_hora Hello, I can set up a wifi network with a router and a bridge this is not a problem.I use Mervis.
Thank you.
@ikiiwii Wifi Configuration is not yet implemented in Mervis, so you would have to configure the wifi client in linux using ssh. Then you will setup SSCP communication between those 2 Neurons.
