DI Not working
Hi Everyone!
I have a small problem, the DI don"t seem to work. I have two unipies, one with the latest non-beta (working flawlessly) and one i tried with beta 1.6 and beta 1.7. These don't work for some reason. I Have a Pi 3b+ so I can't use the non-beta.
Any ideas? Relays are working, CommError on the AO-DI-CNT etc...
Thanks in advance!
Jasper
Hi @jasperjackson,
I have tested your setup and I ran into the same problem. I will discuss this with the dev team and get back to you as soon as possible.Thank you for your patience,
@martin-kudláček many thanks in advance!
Hi @jasperjackson,
so the error is caused by missing evok-mini package in the image. You can SSH into the PLC and under the root user run theapt install evok-minicommand and then reboot the PLC (just to be sure).Martin
Wow! Thanks for the fast solution! I'll try tonight!
@martin-kudláček
It looks like there is another issue with the 1.7, when creating the I2C channel no protocols are listed.. I'll try the 1.6 now...
Jasper
Hi @jasperjackson,
this issue is not caused by the MervisOS, but the MervisIDE. As I can see from the screenshot, you use some ultra-beta version which you probably received from one of my colleagues:) I will send you the latest version we have, but be aware, that it is still a beta with minor bugs and still not ready for production.Martin
Hello again @JasperJackson,
as we discussed via email, the image 1.7 and latest development version of MervisIDE fixes the problem you have encountered. Another problem occured when reading states of the digital inputs. We discovered a problem in the installation package and issued a new version. To fix your problem, SSH into the PLC and issue these commands:sudo su dpkg -P evok-mini pigpio apt-get update apt-get clean apt-get install evok-mini rebootFor clean image 1.7 you just need to install the fixed evok-mini package.
