    How to read PT1000 value, with Neuron S103, in mervis
    • I
      Iogo last edited by
      I have been trying to connect PT1000 to Neuron S103 AO or AI without success.
      Resistance to temperature conversion has been chosen, also PT1000 is selected.
      Neuron S10x_AO_1 resulting in PLC value of -246.8609 etc..
      Tried following youtube tutorial with no success. Should I connect the PT1000 to AI or AO? I bet if I connect resistor to ao or ai, it still shows the same.
      Any ideas?
        tomas_hora administrators @Iogo last edited by
        @Iogo Resistance measurement on S103 is available only on Analog Output (even though it sounds a bit wierd). You have to connect the sensor between AO and AGND. Did you follow the chapetr 2.8.2.1Analog Outputof group 1 (Alternatively Resistance Analog Input–Pt1000)?
        • I
          Iogo last edited by
          Well, at first, i thought it would do these all connections internally after selection has been done with the AO/AI channel to measure resistance and just put it directly to a variable, which would have been easy.. Then I tried the function block, but as you can see..nothing
            @Iogo It seems that the measured resistance is really too small = 9Ω. Is it really Pt1000? And do you really have it connected?
              Btw what are the AO_moed and AO_1 variables? Are they mapped to the HW? It should be like like this. (We might need to update the documentation)
              • I
                Iogo last edited by
                They are mapped to hw, although the name does not imply that. Exactly as in your example. Did not get it to work, so I decided to add a modbus device, 4 channel analog output module and take the pt1000 temperatures through another modbus device...seemed easier way to go =)
