    Solution Contains Unknown Module References
    4 Posts 2 Posters 2.7k Views
      Drewscm
      I am having trouble getting my program to work with an updated Mervis IDE. I used version 2.0.5 on my old computer, and installed version 2.0.12 on my new computer. When I try to open my solution i get a popup that shows the following:
      "Solution contains unknown module references. These references will be removed."
      So when I click ok for the solution to be fixed it opens but when I try to build solution it fails and a long list of warnings shows up in the results.
      Warning Snow 0 1 Changed UID of variable $base$.$sint_to_string$.$eno$.$3f-6b-16-b5-a9-12-be-83-ec-ba-5c-e7-55-b1-fa-ad$
      I could use some help to get this straightened out, I would appreciate it
      Scott
        tomas_hora administrators @Drewscm
        @Drewscm Probably there is another library used in the project which is not part of the IDE 2.0.12 - Check the References under the Executable project menu.
        The log you provided is only a warning, please post the actual error.
          Drewscm
          The issue I am having is the variables. What is the proper way to migrate to a new version of ide? I downloaded the configuration from the PLC, exported and imported the .hw files and added the program. I'm still missing the variables, is it possible to export the variables or am I going to need to enter them all by hand?
            @Drewscm Is this still related to your previous question? Because the issue you described before is caused by a reference to an unexisting library - probably not copied to the Mervis folder, eg: C:\Program Files (x86)\Mervis\IDE 2.1.0 (62613)\Library
            What variables are you missing?
