    Problem recognition 1w-Wire
    19 Posts 4 Posters 9.8k Views 1 Watching
      TriathletC
      I see.
      But if I have to reformat the schema and let it come back virgin how can I do it?
      • zorro_66Z
        zorro_66
        Page 26 of the manual
        Set the PLC to Commissioning mode –Right click on the PLC icon in Solution Explorer and choose PLC Operation→ Commissioning mode
          TriathletC @zorro_66
          @zorro_66
          thank you
            TriathletC
            Goodbye to everyone .. I finally finally managed to recognize the 1-Wire basic temperature sensor of the PLC .. it works properly ..
            But now I need a help ..
            I also bought two sensors of the UNICA Wire Sensor (temperature-humidity and light sensor) all in one.
            The problem is how to connect it .. I have two photos to let you know better.
            Virtually I connected to terminal 5 i + 5V, to 6 the DATA, 7 empty, 8 GND.
            I connected it to the Wire port I tried to make the recognition but with a negative result .. I also attach the screen of how I inserted the device in the Mervis..HO performed the same procedure for the 1-Wire sensor ..2_1504170021892_3.JPG 1_1504170021892_2.JPG 0_1504170021891_1.JPG
              tomas_hora administrators @TriathletC
              @TriathletC Please check the pin map of the RJ45: https://www.unipi.technology/hardware_documentation/1-wire-network-46
              The wiring seems OK, but you have to wire at also both data lines to the sensor, or you break the topology.
              Also, do not strip the end of cables when you make the RJ45 connector. The connector cuts the plastic foil of the cable when you press it with the crimping tool. If you strip the cables before, the cables can touch each other which could cause shortcut....
                TriathletC
                So from what you tell me I have to bring another thread and jump to the DQ. right?
                  @TriathletC Correct
                    TriathletC @tomas_hora
                    Thanks Thoma ... you were right I wore everything as you said and it works correctly .. so I need an info .. how do I parameterize the UR%?
                      @TriathletC You are welcome... But now I do not understand. Could you describe it better please?
                        I do not know how to configure correctly so that I can read the relative uimness on the mervis I attach to the screens.1_1504260494139_Cattura_2.JPG 0_1504260494139_Cattura_1.JPG
                        D 1 Reply Last reply
                          David @TriathletC
                          @TriathletC Try to use FUPLA block called 'unica_u1wt'.
                            TriathletC @David
                              David
                              Yes, that it should work.
