    First start with unipi / MERVIS
    15 Posts 7 Posters 11.1k Views
      tomas_hora administrators
      Sudo is not needed since you are already logged in as root user. Just run the apt-get and other commands without sudo. Mervis is a set of IDE (windows application) and RunTime (configtool+runtime - runs on the RPi). So you program behavior of your system using the IDE on Windows and upload the program to the UniPi. So you do not need a desktop inteface on RPi, but if you want it, then it of course can be installed.
      The latest version of Mervis recommended for UniPi is always available only at our web pages, so do not mind the update from the IDE.
      To be hones, getting online data is a nightmare in Mervis. The easiest solution might be to create eg. a python script that will take care of the requests and write a data to a file where mervis could read it using a ST program (But did not tried yet!)
      @nordeck No-one is a noob for us. We created UniPi to provide easy automation for everyone :)
      • N
        nordeck
        What do you mean with ST program?
        I had an Idea to build wifi temperature sensor using "mode mcu" (http://www.jerome-bernard.com/blog/2015/10/04/wifi-temperature-sensor-with-nodemcu-esp8266/) and write values into some file on rsb (or somewhre else in local network). Then read this file with mervis. I need update every 5mins.
          In Mervis, there is 'programming language' for PLCs called ST (structured text). It is not that powerful as C so do not expect much, but you are able to do some basic stuff. I will try to take a look at it, if it is possible to read external files (not sure yet). If yes, then you would need to write e.g. a python script to read the temperature from the ESP periodically and write the temperature to a file, which might be read by Mervis.
          G 1 Reply Last reply
          • N
            nordeck
            • K
              karel505
              Thank you for your replies, that was what I needed. For now.
              I did get mervis to work in a very simple setup.
              Learning a lot, it is fun.
              • L
                lindseynicole010
                thanks for that.
                  pratvictor @tomas_hora
                  @tomas_hora said in First start with unipi / MERVIS:
                  The default password for root of the mervisOS is: unipi
                  @karel505 I do not understand what is your question... The mervisOS is a Deb Jessie only with installed mervis. If you wish to disable it, just run
                  systemctl stop configtool
                  systemctl stop sharkrt
                  systemctl disable configtool
                  systemctl disable sharkrt
                  The FileSystem is readonly so if you wish to write to any file
                  mount -o remount,rw /
                  and then mount it as redonly again by
                  mount -o remount,ro /
                  @nordeck If the IP address has changed, you need to atach the PLC(UniPi) again. If you mean the battery for RTC, then it is CR2032.
                  If I want to set an static ip to the raspberry, I should do it that way? Could I do it trough Mervis? I didn't find how to set an static IP...
                  Thanks!!
                    tomas_hora administrators @pratvictor
                    @pratvictor if you are using mervis, then you can of course set static IP using the IDE. Just select the PLC chek the network properities on the right side. You have to upload the configuration afterwards (acessible from right click on PLC)
                    • G
                      Giamba @tomas_hora
                      • G
                        Giamba @Giamba
                        @Giamba said in First start with unipi / MERVIS:
                        In Mervis you can create a Modbus TCP channel that then connects to another program on the local machine or on a network machine. It is enough then to create a program in C with the library modbus, in the example that follows, I also use the library zmq which gives me real-time messages from any program, from everywhere. This one gives me the data of my weather station WMR200.
                        > #include <stdio.h>
                        > #include <unistd.h>
                        > #include <string.h>
                        > #include <stdlib.h>
                        > #include <errno.h>
                        > #include <modbus.h>
                        > #include <zmq.h>
                        > #include "zhelpers.h"
                        > int arrondi(float nombre) {
                        >   return nombre + 0.5;
                        > int main()
                        >     int socket;
                        >     modbus_t *ctx;
                        >     modbus_mapping_t *mb_mapping;
                        >     int keepRunning;
                        >     int rc;
                        >     char src[sizeof("WMR200_USB")];
                        >     char pressure[sizeof("0000.0")];
                        >     char humid0[sizeof("000.0")];
                        >     char humid1[sizeof("000.0")];
                        >     char temp0[sizeof("-000.0")];
                        >     char temp1[sizeof("-000.0")];
                        >     char windGust[sizeof("000.0")];
                        >     char windAvg[sizeof("000.0")];
                        >     char windDir[sizeof("000.0")];
                        >     char zmq_msg[100];
                        >     printf("Start WView WMR200 ZMQ/Modbus gateway\r\n");
                        >     fflush(stdout);
                        >     keepRunning = 1;
                        >     while(keepRunning == 1) {
                        >         printf("Waiting for TCP connection...\r\n");
                        >         fflush(stdout);
                        >         ctx = modbus_new_tcp("127.0.0.1", 1502);
                        >         socket = modbus_tcp_listen(ctx, 1);
                        >         modbus_tcp_accept(ctx, &socket);
                        >         printf("TCP connection started!\r\n");
                        >         fflush(stdout);
                        >         mb_mapping = modbus_mapping_new(1000, 1000,
                        >                                         1000, 1000);
                        >         mb_mapping->tab_registers[0] = 0; //pressure
                        >         mb_mapping->tab_registers[1] = 0; //temp sensor 0 temp  (station temp)
                        >         mb_mapping->tab_registers[2] = 0; //temp sensor 0 humid
                        >         mb_mapping->tab_registers[4] = 0; ///temp sensor 1 temp (out temp)
                        >         mb_mapping->tab_registers[5] = 0; //temp sensor 1 humid
                        >         mb_mapping->tab_registers[7] = 0; //wind gust
                        >         mb_mapping->tab_registers[8] = 0; //wind avg
                        >         mb_mapping->tab_registers[9] = 0; //wind dir
                        >         if (mb_mapping == NULL) {
                        >             fprintf(stderr, "Failed to allocate the mapping: %s\r\n",
                        >                     modbus_strerror(errno));
                        >             modbus_free(ctx);
                        >             return -1;
                        >         void *context = zmq_ctx_new ();
                        >         void *subscriber = zmq_socket (context, ZMQ_PULL);
                        >         rc = zmq_bind (subscriber, "tcp://*:5560");
                        >         assert(rc == 0);
                        >         while(1) {
                        >             memset(zmq_msg, 0, sizeof(zmq_msg));
                        >             int size = zmq_recv (subscriber, zmq_msg, 2048, ZMQ_DONTWAIT);
                        >             if (size != -1) {
                        >                 //  Process task
                        >                 //printf("%s\n\r", zmq_msg);
                        >                 fflush(stdout);
                        >                 sscanf (zmq_msg, "%s %s %s %s %s %s %s %s %s",src, pressure, temp0, humid0, temp1, humid1, windGust, windAvg, windDir);
                        >                 printf("WMR200 Modbus Gateway from ZMQ: topic=%s pressure=%s temp0=%s humid0=%s temp1=%s humid1=%s winGust=%s windAvg=%s windDir=%s\r\n", src, pressure, temp0, humid0, temp1, humid1, windGust, windAvg, windDir);
                        >                 fflush(stdout);
                        >                 if (strcmp(src, "WMR200_USB") ==0){
                        >                     mb_mapping->tab_registers[0] = arrondi(atof(pressure)); //pressure
                        >                     mb_mapping->tab_registers[1] = arrondi(atof(temp0)*10); //temp sensor 0 temp  (station temp)
                        >                     mb_mapping->tab_registers[2] = arrondi(atof(humid0)*10); //temp sensor 0 humid
                        >                     mb_mapping->tab_registers[3] = arrondi(atof(temp1)*10); ///temp sensor 1 temp (out temp)
                        >                     mb_mapping->tab_registers[4] = arrondi(atof(humid1)*10); //temp sensor 1 humid
                        >                     mb_mapping->tab_registers[5] = arrondi(atof(windGust)*10); //wind gust
                        >                     mb_mapping->tab_registers[6] = arrondi(atof(windAvg)*10); //wind avg
                        >                     mb_mapping->tab_registers[7] = arrondi(atof(windDir)*10); //wind dir
                        >             uint8_t query[MODBUS_TCP_MAX_ADU_LENGTH];
                        >             rc = modbus_receive(ctx, query);
                        >             if (rc >= 0) {
                        >                 //printf("Replying to request.\r\n");
                        >                 modbus_reply(ctx, query, rc, mb_mapping);
                        >                 //fflush(stdout);
                        >             } else {
                        >                 printf("Quit the loop: %s\r\n", modbus_strerror(errno));
                        >                 fflush(stdout);
                        >                 zmq_close (subscriber);
                        >                 zmq_ctx_destroy (context);
                        >                 modbus_mapping_free(mb_mapping);
                        >                 close(socket);
                        >                 modbus_free(ctx);
                        >                 break;
                        >     return 0;
                        Then in Mervis you have to configure modbus data point.
                        C 1 Reply Last reply
                          CaitC @Giamba
                          @Giamba I see that you are posting C source. I have found python in /usr/bin but I do not find any gcc or make anywhere. There is also no java installed. I am not an RPi user (I use nV embedded systems) so am not familiar with Jessie ... do I need to install these programming runtimes and environments? Do you know what size SD card I need to get to this environment?
