    unipi 1.1 + pi3 and 1Wire DS18B20 bus problem
    Scheduled Pinned Locked Moved CODESYS
    12 Posts 4 Posters 8.5k Views
      tomas_hora administrators @Alverman
      @Alberto-Cauzzi Hello,
      so you are using the kernel module for 1Wire? Please paste more info, eg. how did you configure it, what happens if you put more sensors on the network, etc..
      AlvermanA 1 Reply Last reply
      • AlvermanA
        Alverman @tomas_hora
        I have:
        PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
        NAME="Raspbian GNU/Linux"
        VERSION_ID="8"
        VERSION="8 (jessie)"
        ID=raspbian
        ID_LIKE=debian
        HOME_URL="http://www.raspbian.org/"
        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        and
        Linux PI3_MMM 4.4.34-v7+ #930 SMP Wed Nov 23 15:20:41 GMT 2016 armv7l GNU/Linux
        In PI config I have enabled 1wire
        The sensor is connected to the RJ45 port UNIPI 1.1
        I also have a hub (yours) to 8 channels (in and out included) but for now I wanted to try it by connecting the sensor directly to unipi
        Thanks, Alberto
        • AlvermanA
          Alverman
          0_1488551302845_upload-383c6e3c-d159-4e9b-b952-0d9724fed53a
          • AlvermanA
            Alverman @Alverman
            @Alberto-Cauzzi
            this project is for raspberry not for unipi and not work with sensor connected on 1wire unipi port.
            The error is only bad image reference
            • AlvermanA
              Alverman
              0_1488551821112_upload-e1394848-83c9-4084-8a1c-2dc61aaeccf4
              • AlvermanA
                Alverman
                In CoDeSys only it works unipi 1.1 card.
                In CoDeSys the expansion board i2c to 8 relays and 1wire bus DO NOT WORK !!
                  I guess you did not read the manual which describes the installation really nicely. The Raspi-config you used enables 1Wire via GPIO but the 1Wire we are using is connected via I2C...
                  Please follow the datasheet as described https://store.codesys.com/codesys-for-unipi.html
                  • L
                    lefrank01
                    I got this problem few time ago. The sample project gived by Codesys isn't perfect but with this program you can get the address.
                    -First thing I see is to disable 1-Wire. Because Codesys will try to ping 1-wire Bus from the raspberry pi board and not the 1-wire Bus from UNIPI board. Because the UNIPI BUS is over I2C.
                    The best thing to do is to run the installation script. But for this, you need to log into the root session.
                    Put the script into USB KEY.
                    click right on the script, property.
                    permission - and bring it executable from anyone.
                    then double click on the script.
                    Run from terminal.
                    There the script gonna get you the correct configuration. Make sure internet work because if my memory is good it have to download something.
                    I did this on a clean install of pixel. And after that everything was fine.
                    With my best regard,
                    Mathieu lefrançois
                    D 1 Reply Last reply
                    • L
                      lefrank01
                      IF NOT x THEN
                      x := TRUE;
                      //scan function
                      FOR ui:=1 TO MIN(Onewire_master.uiScannedDevices, 20) DO
                      astrID[ui] := Onewire_master.pasScannedDevices^[ui-1].StringRepresentation;
                      END_FOR
                      END_If
                      Run this code into a seperate POU (ST language)
                      x=bool
                      astrID=array
                      ui=UINT
                      Mathieu lefrançois
                      • L
                        lefrank01
                        with this, look online the string of the array. from 1 to 20 DS18B20 correctly wired you will have the address.
                        Once that done, you need to insert the address manually of each DS18B20 into codesys DS18B20. If you use more than 1 DS18B20, you have to click on the DS18B20 already existing, ADD new device and add another DS18B20.
                        Mathieu lefrançois
                        Reply Quote 1
                          DavidCozens @lefrank01
                          @lefrank01 thank you for sharing your tips. I have also had this reported once or twice and on each occasion starting from a clean install of Raspbian, installing CODESYS for Raspberry Pi and then running the script that ships with CODESYS for UniPi has resolved users problems.
