Charlyplexing or matrix
@Wim-Stockman Thanks for the report. See this modification of the on_message function:
try: device = Devices.by_name(dev, circuit) # result = device.set(value) func = getattr(device, cmd) if value is not None: result = func(value) else: result = func() if is_future(result): result = yield result #devents.status(device) self.write_message(result) #print json.dumps(result) except Exception, E: print EIt will send the result of the command to only the client that send the command. But in our test, you are using two clients, so you will not receive the result in the other client. If you want to send the result to all clients connected to the WebSocket, use the devevents.satus(device) insted.
Working example of the test client:
import websocket import json import time import threading url = "ws://127.0.0.1/ws" i = 0 relaystatus = [0,0,0,0,0,0,0,0] #initiliaze relay 3 just for demo purpose wsinit = websocket.create_connection("ws://127.0.0.1/ws") time.sleep(2) wsinit.send('{"cmd":"full","dev":"relay","circuit":"3"}') while True: result = json.loads(wsinit.recv()) if result['dev'] == 'relay': print result wsinit.close()I will commit it in the first week of January.
Hi thx,
This works !
But now I get a weird exception on the evok.py on line 140 it throws an exception:
I get "Expected bytes, unicode, or None; got <type 'int'>"
Each time I sent a message : wsinit.send('{"cmd":"set","dev":"relay","circuit":"3","value":"1"}')It's like it iterates twice over the on_message loop
my demo code is
import websocket import json import time import threading url = "ws://127.0.0.1:8088/ws" i = 0 global relaystatus relaystatus = [0,0,0,0,0,0,0,0] #initiliaze relay 3 just for demo purpose wsinit = websocket.create_connection("ws://127.0.0.1:8088/ws") time.sleep(2) wsinit.send('{"cmd":"full","dev":"relay","circuit":"3"}') result = json.loads(wsinit.recv()) relaystatus[2]=result["value"] while True: result = json.loads(wsinit.recv()) if result['dev'] == 'input': if relaystatus[2]==0 : wsinit.send('{"cmd":"set","dev":"relay","circuit":"3","value":"1"}') relaystatus[2] = 1 else: wsinit.send('{"cmd":"set","dev":"relay","circuit":"3","value":"0"}') relaystatus[2] = 0 print result wsinit.close()Thanks for the great help already :-)
Wim -
@Wim-Stockman I saw your pull request.. Did you find out what it was with the Expected bytes, unicode, or None; got <type 'int'>"? On what code did it crash?
So I found the problem, solved it and put a pull request in github.
made a little change in the evok.py.
#adding support to get state of relays using full msg in cmd if cmd == "full": self.write_message(result) -
@tomas_hora yes the on_events routing fired a new message for the status change of the relay which was captured by the on_message and since it just sented a 0 or 1 the on_message gave this weird thing
This post is deleted! -
So I finished the hardware part for the input plexing.
I used a variation on the charlyplexing.In the example breadboard I only used 4 digital inputs (symbolized by the Leds), the 12V Vcc is symbolized by the battery and 8 pushbutton : https://circuits.io/circuits/3580634-stockmaninputplexing.
You could attach up to 15 pushbuttons on 4 digital inputs with this method. It is just some binary logic behind and a lot of diodes :-)
The purple wires are connected to an input just directly. (you could place diodes for safety)
and the next 6 pushbuttons are connected through 2 wires.
If you want 4 more pushbuttons you should combine 3 wires
and for the last one you need 4 wires.So in theory with this method you could make 16383 different input combinations with this method.
I think it will not be practical but with 2 wires you can easily attach up to (14²-1) 195 pushbuttons with each different reactions.
So know I will create a python class to handle these inputs using the websocket method :-) -
Is there a possibility to receive the inputs via websocket with timestamps.
I know the pigpio librabry does this, but since the new neurons don't work anymore with pigpio. I was wondering if this is possible would be easy to detect , long pressed buttons etc... -
I have written some code to detect two inputs simultaniously activated through websocket.
Here is the code#timingclass import websocket import threading import datetime import json import time url = "ws://192.168.1.104:8088/ws" class DI: def __init__(self,circuit,value,timestamp): self.circuit = circuit self.value = value self.timestamp = timestamp self.longpress = 0 self.doubletap = 0 class homecontrol: def __init__(self,websock_evok_url): self.status = 0 self.digitalinput_list = [[0,0],[0,0]] # create list with timestamp inputs self.timeout = 1000 self.websock_evok_url = websock_evok_url #connect to websocket and spawn message thread self.ws = websocket.WebSocketApp(url, on_message = self.on_message, on_error = self.on_error, on_close = self.on_close) self.wst = threading.Thread(target=self.ws.run_forever()) self.wst.daemon = True self.wst.start() def time_stamp_inputs(self): t = datetime.datetime.now() t = (t.second * 1000)+(t.microsecond / 1000) return t def detect_if_pressed_together(self): d1 = self.digitalinput_list[0] d2 = self.digitalinput_list[1] # must be two different inputs and the same values you cannot press and unpress at the same time if d1.circuit != d2.circuit and d1.value == d2.value: t = d1.timestamp -d2.timestamp if t < self.timeout: return 1 else: return 0 def on_message(self,ws, message): self.obj = json.loads(message) print self.obj self.dev = self.obj["dev"] self.circuit = self.obj["circuit"] self.value = self.obj['value'] if self.dev == "input" and self.value == 1 : digitalinput = DI(self.circuit,self.value,self.time_stamp_inputs()) self.digitalinput_list.insert(0,digitalinput) if(self.detect_if_pressed_together()): l = (self.digitalinput_list[0].circuit,self.digitalinput_list[1].circuit) l = sorted(l) x = str(l[0])+str(l[1]) self.digitalinput_list[0].circuit = int(x) x = self.digitalinput_list[0] proc = threading.Thread(target=self.proceed_input,args=(x,)) proc.start() def detect_long_press_of_button(self): pass def proceed_input(self,I):# SETUP a method to declare what to do which each function , was thinking of using codeblocks for this part ? if I.circuit == 17: print I.circuit relay = 5 t = threading.Thread(target=self.switch_rel,args=(relay,)) #t = threading.Thread(target=switch_on_off_relay,args=(relay,)) t.start() print "thread" if I.circuit == 26: print "26" relay = 1 c = threading.Thread(target=self.switch_rel,args=(relay,)) c.start() print "thread2" def on_error(self,ws,error): print "error" print error def on_close(self,ws): print "connection closed" def switch_rel(self,c): relaynumber = c self.ws.send('{"cmd":"set","dev":"relay","circuit":"'+str(relaynumber)+'","value":"0"}') #else: # self.ws.send('{"cmd":"set","dev":"relay","circuit":"'+str(relaynumber)+'","value":"0"}') # self.status = 1 # SETUP a method to declare what to do which each function , was thinking of using codeblocks for this part ? def switch_on_off_relay(c): print c relaynumber = c url = "ws://192.168.1.104:8088/ws" ws = websocket.create_connection(url) print "swdf" ws.send('{"cmd":"set","dev":"relay","circuit":"'+str(relaynumber)+'","value":"1"}') ws.send('{"cmd":"set","dev":"relay","circuit":"'+str(relaynumber)+'","value":"0"}') ws.close pass x = homecontrol(url)But I have a problem that some inputs when they are to fast one after each other get forgetten.
and if I do none multithreading it does do al the steps but then one push may hold the others so not good.
Can somebody help me ? -
@Wim-Stockman I will take a look at it during the next week. Thanks for the tip.
I did not check the code much but there should be some time buffer while decoding the correct input. The messages does not always come at the same time, there might be a tens of ms gap between each and you shoudl tie those together...
